Breather hose connection help
twt
PostPosted: Mon Apr 07, 2003 1:42 am    Post subject: Breather hose connection help Reply with quote
Can someone help me indentify where the piping from the breather hose goes to? On the engine breather hose, there is a Y joint with 1 pipe going to the air/oil seperater. Does anyone know where the other pipe is connected to?
This is the breather hose I'm talking about (the portion with the 2 tubes).
Thanks!
PostPosted: Tue Apr 08, 2003 12:31 am    Post subject: Reply with quote
Just so you know you're not getting ignored.. I'd help ya but my car doesn't have a Y on that breather hose - just one line to the oil seperator.
twt
PostPosted: Tue Apr 08, 2003 12:41 am    Post subject: Reply with quote
Thanks for your reply. Maybe it's only on the '80 model then (that's mine). I installed the turbo oil vent pipe (the one with the square box) but instead of piping it to the engine head, my mechanic routed it to the breather hose. Was just wondering if that will work, or should I try to get hold of the pipe which leads to the engine head?
John Brown
PostPosted: Fri Apr 11, 2003 6:12 am    Post subject: Reply with quote
Your mechanic did right. That's where it used to go.
twt
PostPosted: Sat Apr 12, 2003 2:44 am    Post subject: Reply with quote
Thanks for the clarification!
