twt
Posted: Mon Apr 07, 2003 1:42 am Post subject: Breather hose connection help |
Can someone help me indentify where the piping from the breather hose goes to? On the engine breather hose, there is a Y joint with 1 pipe going to the air/oil seperater. Does anyone know where the other pipe is connected to?
This is the breather hose I'm talking about (the portion with the 2 tubes).
Thanks! |
Posted: Tue Apr 08, 2003 12:31 am Post subject: |
Just so you know you're not getting ignored.. I'd help ya but my car doesn't have a Y on that breather hose - just one line to the oil seperator. _________________ "..it's made in Germany. You know the Germans always make good stuff."
twt
Posted: Tue Apr 08, 2003 12:41 am Post subject: |
| Thanks for your reply. Maybe it's only on the '80 model then (that's mine). I installed the turbo oil vent pipe (the one with the square box) but instead of piping it to the engine head, my mechanic routed it to the breather hose. Was just wondering if that will work, or should I try to get hold of the pipe which leads to the engine head? |
John Brown
Posted: Fri Apr 11, 2003 6:12 am Post subject: |
| Your mechanic did right. That's where it used to go. |
twt
Posted: Sat Apr 12, 2003 2:44 am Post subject: |
| Thanks for the clarification! |
