Brake Pedal "feel"
Goto page Previous  1, 2
Mars478
PostPosted: Wed Jun 18, 2014 1:05 am    Post subject: Reply with quote
Pardon my noobish-ness but I've never worked on drum brakes before this car. So I can adjust the rear drums without having to remove the axle nut?
924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
PostPosted: Wed Jun 18, 2014 1:32 am    Post subject: Reply with quote
OK, brother. . .time to pony up for a manual.
Mars478
PostPosted: Wed Jun 18, 2014 1:34 am    Post subject: Reply with quote
I've got the Haynes, is that good enough? What would you recommend?
PostPosted: Wed Jun 18, 2014 4:17 am    Post subject: Reply with quote
Perhaps reading the section on Brakes?
Captain_Kirk
PostPosted: Wed Jun 18, 2014 4:31 am    Post subject: Reply with quote
Don't remove nut. Shoes adjust from the backside of the backing plate. Lay on the ground under the rear bumper, look at the backside of backing plate, there are four holes, or maybe you still have the rubber plugs in them.
Hardest part is figuring which way to turn them to tighten. Once that is figured out, I put an arrow next to each one to make the next time easier.
1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body
Mars478
PostPosted: Fri Jun 20, 2014 6:48 am    Post subject: Reply with quote
My attempt to adjust the drum brakes failed horribly when the adjusting "gear" was rusted solid. Therefore I couldn't tell which one of the gears was the right one. *sigh* this car is difficult sometimes.
Page 2 of 2
