1987 924s timing question
ggrecian
PostPosted: Mon Dec 09, 2013 6:24 am    Post subject: 1987 924s timing question Reply with quote
please forgive the elementary question.i am am amatueur mechanic at best.took off manifold gasket to fix vacuum leak.put it all back together now crank no start.firing order is correct.what could cause the car to get out of timing?could replacing manifold gaskets and trying to start it 1000 times after changing over parts and sensors cause the car to get out if timing?
porschelover
PostPosted: Mon Dec 09, 2013 1:42 pm    Post subject: Reply with quote
Fuel? Spark?
larchie
PostPosted: Mon Dec 09, 2013 2:30 pm    Post subject: Reply with quote
If this is for the same car questioned in your past individual threads on this forum on Oct 27nd, two on 28th, Nov 2nd, 3rd, 7th, 8th and 10th, then the two things which come to mind are ...
(1) By reversing the sensors and then re-installing in the proper order the speed sensor and reference mark sensor is accidentally picking up metal filings magnetically or the like and so not having the proper clearance for proper readings.
(2) Problems with the timing -- use ideola's troubleshooting help outlined in these threads:
http://www.924board.org/viewtopic.php?t=39217
http://www.924board.org/viewtopic.php?t=39232
http://www.924board.org/viewtopic.php?t=39292
on how to solve the ignition/timing issues, esp. with regard to the reassembly with the distributor.
PostPosted: Mon Dec 09, 2013 4:33 pm    Post subject: Reply with quote
Um, OPs car is a 2.5 with Motronic. . .
ggrecian
PostPosted: Mon Dec 09, 2013 8:54 pm    Post subject: Reply with quote
Yea same car in previoua threads.thank you for guidance.Have fuel with adequate pressure (36psi)to the fuel rail.and have spark.sent away dme to be bench tested.trying to rule out timing issue in the meantime.
porschelover
PostPosted: Tue Dec 10, 2013 10:39 am    Post subject: Reply with quote
So, just to clarify, your car does not have a conventional distributor, and does not have adjustable timing in the conventional sense. The ignition rotor is attached to the end of the camshaft, and ignition timing is controlled by the DME. If you are getting spark and fuel pressure, you likely have a crank speed/reference sensor problem. The most common culprits are wrong installation (plugs reversed) or a wiring fault at the connector. This assumes that you did not disturb the sensor bracket and mess up the gap.
If you don't know the history of the sensors, I think best practice is to replace both. The cheap replacement is Facet 12141710668. Both sensors are the same part.
PostPosted: Tue Dec 10, 2013 9:42 pm    Post subject: Reply with quote
] If you are getting spark and fuel pressure, you likely have a crank speed/reference sensor problem. The most common culprits are wrong installation (plugs reversed) or a wiring fault at the connector. If you don't know the history of the sensors, I think best practice is to replace both. The cheap replacement is Facet 12141710668. Both sensors are the same part.
This is sound advice since messing with the manifold gasket usually disturbs the crank sensor connections which can often be brittle after 20 plus years.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
