Email: i97lafr@itek.chalmers.se
Date: 08 Mar 2000
Time: 14:06:05To adjust the timing correctly you will need a stroboscope lamp, which is a tool that you can buy at any auto parts store. Since these lamps cost about $40-80, it might be a good idea to leave the job to a mechanic who already has the tool. To get the correct setting you must also find out what the correct timing value is for your car (usually stated on a sticker in the engine bay or in the owner's manual). Here you can also see if the value is to be set with the ignition vacuum hose connected or disconnected.
/Fredrik
