Timing
Guest
PostPosted: Wed Mar 08, 2000 12:51 pm    Post subject: Reply with quote
Email:
Date: 08 Mar 2000
Time: 13:51:39
I remember when I bought my 924 they said the smog tech had to retard the timing or something to get the car to pass smog, so how do I adjust the timing to where it should be? thanks!
Guest
PostPosted: Wed Mar 08, 2000 1:06 pm    Post subject: Reply with quote
Email: i97lafr@itek.chalmers.se
Date: 08 Mar 2000
Time: 14:06:05
To adjust the timing correctly you will need a stroboscope lamp, which is a tool that you can buy at any auto parts store. Since these lamps cost about $40-80, it might be a good idea to leave the job to a mechanic who already has the tool. To get the correct setting you must also find out what the correct timing value is for your car (usually stated on a sticker in the engine bay or in the owner's manual). Here you can also see if the value is to be set with the ignition vacuum hose connected or disconnected.
/Fredrik
Guest
PostPosted: Mon Mar 13, 2000 2:46 am    Post subject: Reply with quote
Email: aminolabs@yahoo.com
Date: 13 Mar 2000
Time: 03:46:25
There is a relationship between the octane of the fuel and the advance of the spark timing. The real answer is: as advanced as possible without causing the engine to "ping." The higher the octane the greater the advance.
Racing cars burning 105 octane fuel will be in the 20+ range. Gasoline Drier (methanol) is an inexpensive octane boost.
I knew this old time country mechanic that would time an engine by setting the distributor and accellerate up a hill. He would continue to advance the engine until it would ping. Then adjust it back 1 degree. None of his customers ever complained.
Guest
PostPosted: Mon Mar 13, 2000 5:35 pm    Post subject: Reply with quote
Email: apple_bit@mac.com
Date: 13 Mar 2000
Time: 18:35:02
I have found that the early (77.5 pre's) distributor have the far best advance. Place one of those on your car to get some extra high end power.
Also- I have found that advancing the timing should be done carefully. You can easily advance it too much! This was proven on a dyno readout! Please take caution to this!
