Magnus K
Joined: 25 Oct 2003 Posts: 151 Location: Linkoping, in Sweden
Posted: Wed Jul 21, 2004 4:21 pm Post subject: Engine hesitation when hitting the gas pedal fast |
Hi!
My 924 NA hesitates when i hit the gaspedal hard and fast. This is worse when the engine is cold but it can be felt even if the engine is warm.
Just another thing with these engines or can I do something about it?
Regards
Magnus _________________ Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake... |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Wed Jul 21, 2004 4:56 pm Post subject: |
Timing slightly out perhaps? Can't say that I've noticed any hesitation from mine, though i can't say i've jumped on the pedal quick either.. _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
Magnus K
Posted: Wed Jul 21, 2004 5:25 pm Post subject: |
OK, I'll try to adjust the timing first, to see if that will cure it.
My 924 got a "slight" problem with timing adjustment though... It seems like the timing marks on the "big metal thingey at the end of the motor just before the clutch" (my English word just took a holiday there, sorry ) is non-existing. Maybe that the PO has mounted the thingey with the timing marks the wrong way, cause I couldn't see any marks when I was looking the last time...
Thanks for the tips anyway!
Posted: Wed Jul 21, 2004 6:06 pm Post subject: |
Flywheel
I borrowed a timing strobe for mine, spent ages trying to use the thing but the marks are damned impossible to see in there... in the end I just kept adjusting things a little and running her until she ran smooth.
I usually have a hell of a time getting the gap set correctly on the contact breaker/points too, seems to be a fine line between the perfect gap and one where she runs rough. _________________ Mars Red '78 Euro 924 n/a
Magnus K
Posted: Wed Jul 21, 2004 8:06 pm Post subject: |
| 5150 wrote: | Flywheel  |
Ow, yeah! That's the one!
OK, I'll try and adjust the timing without the strob and flywheel markings.
Thanks!
wdb
Posted: Wed Jul 21, 2004 9:45 pm Post subject: |
| a hesitation when you give it gs can be caused by a rich mixture , too much gas chokes the motor . |
Magnus K
Posted: Wed Jul 21, 2004 9:48 pm Post subject: |
wdb - OK, can that be adjusted by turning the CO adjustment screw?
/Magnus _________________ Another curious Swede...
D Hook
Posted: Wed Jul 21, 2004 11:10 pm Post subject: |
Is this a new occurence or has it always been this way?
I'd check for air leaks on the boots and check the fuel pressures before adjusting the CO screw. There's alot of different things that can cause what you describe and sometimes changing the CO only masks the real problem. Do you have access to a CIS pressure tester by chance? Testing and eliminating the fuel pressure system as the problem saves alot of money and time and can sometimes pinpoint the problem for you. Let us know what you find. |
Magnus K
Posted: Wed Jul 21, 2004 11:42 pm Post subject: |
New quirk or always = I donīt know. I bought the ca in November last year and it spent all winter on 4 jack stands while I rebuilt the floor pan. Air leaks and other things related to aging components is a probability here...
CIS tester = something to measure fuel pressure in the fuel distributer = K-Jetronic unit? Nope, sorry. Maybe later I can install some gauges in the system but not right know.
I think I see what you mean by "saving a lot of money and time". The time I got but no money... I'll try setting the timing first and take it from there.
Thanks!
Chrenan
Posted: Thu Jul 22, 2004 12:38 am Post subject: |
Magnus,
So basically the guys have narrowed it down to one of 2 things, the timing is off or the fuel mixture is too rich. Here's a few tips for both issues as I've had similar problems in the past with my car.
Before you use the timing light, turn the motor by hand using the nut on the oil pump pulley while looking at the flywheel. When you see a number or marking on the flywheel stop turning the motor and clean the number or marking (a timing mark). I use carb cleaner and a rag to wipe the timing mark clean. Then put a dot of white paint beside the timing mark. Now when you use the timing light gun, the timing marks will really stand out.
There is a cheap test to check if your mixture is rich. Let your car warm up, then while it idles, put your hand in front of the exhaust. If you see small black/brown specks accumulate on your hand (un-burned fuel), it could be the sign of a rich mixture. Anyway, I wouldn't just turn the CO screw to adjust the mixture without finding out why it is rich in the first place. Have you changed the Oxygen Sensor lately (if your car has one)? Past 30,000 km the Oxygen Sensor will start to fail and the mixture will richen. Also, is your frequency valve working? It is my understanding that if it fails, it fails in the open position, which richens the mixture. If you've ever heard one of these little devices in action, you'll know if your isn't working, they make an annoying high pitched buzzing sound when they are working.
Hope that helps,
Chrenan _________________ 1987 951 - M193 Version for Japan |
Magnus K
Posted: Thu Jul 22, 2004 9:11 pm Post subject: |
Chrenan, thanks!
CO sensor - No, ny car doesn't one of those.
Frequency valve? What is that and where should it be located? And what function does it serve?
Regards
Chrenan
Posted: Fri Jul 23, 2004 12:09 am Post subject: |
If you have no Oxygen Sensor, then you have no frequency valve, they work together. That's good, it eliminates that as a possible source for a rich running condition. Your car is from before 1980? What year? _________________ 1987 951 - M193 Version for Japan |
Porchenewbe
Joined: 04 Jun 2004 Posts: 30 Location: stoke on trent
Posted: Fri Jul 23, 2004 6:13 am Post subject: |
Just had MOT on my car, passed with no prob's, but theMOT dude turned down the CO screw to weaken the mixture, was running like yours by the sounds of things! so i had the engine dyno tuned and it sorted the problem right out, sorting mixture and timing gave me 11 bhp, making a total of 131 bhp. So thats what i recommend, car runs sooo much better. Sweet!!
Hope that helps.
john _________________ Riding a steep learning curve about all that is 924.
My first porsche ... I'm only 19..But loving it (except the insurance) ... quite some car. |
Magnus K
Posted: Fri Jul 23, 2004 7:30 pm Post subject: |
| Chrenan wrote: | | If you have no Oxygen Sensor, then you have no frequency valve, they work together. That's good, it eliminates that as a possible source for a rich running condition. Your car is from before 1980? What year? |
It's a 1979 Euro 924 NA, hence the non-existing oxygen sensor, I think?
The yearly safety inspection (Swedish version of the MOT, I think) measured the CO value and it seems to be about right.
I think I'll try to check out the timing, should be the no 1 thing to do.
Thanks to all!
Chrenan
Posted: Sat Jul 24, 2004 12:00 am Post subject: |
| Quote: | | It's a 1979 Euro 924 NA, hence the non-existing oxygen sensor, I think? |
Correct, oxy/freq system started in 1980 in order to reduce emmissions and increase fuel economy... _________________ 1987 951 - M193 Version for Japan |
