931 custom in need of some love
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Mclaren924
PostPosted: Wed Apr 08, 2026 2:31 am    Post subject: Reply with quote
Wilwoods mounted up to 924 5 lug hubs to get rough idea of where all the brake lines will run. Converting to a stepped 944 master cylinder as well as F+R brake line routing instead of the X-split that is standard on the 924/931.
Will be converting to 924S front hubs and rear trailing arms/hubs/ The aluminum rear saves a lot of unsprung weight.
Installing a tilton Proportioning valve alongside the passenger trans tunnel and will finish off the brake upgrade with stainless steel hardlines, and braided soft lines to wrap it up.
Just got it all mocked up and time to mount the valve and booster/master and start bending brake line
PostPosted: Wed Apr 08, 2026 6:38 am    Post subject: Reply with quote
Slowly getting there! Do you make the adapters yourself? I really recommend the carrera discs up front while you are there, they cost very little and add quite a bit of extra cooling with the extra 3mm width.
I think the 944 MC only use the large piston normally if i remember correctly, so it will only act with the smaller area in case of brake failure. But with the bias valve you should be able to get it working, what pistons did you chose?
Mclaren924
PostPosted: Wed Apr 08, 2026 7:19 am    Post subject: Reply with quote
Just the wagenwest kit, it's the 944 setup and fits our 5 lug hubs perfectly. Will look into the carrera discs upfront, thank you for recommendation.
https://wagenswest.com/product/porsche-944-wilwood-caliper-kit-front-rear/
Got booster and master mounted up and intake mounted and started bending drivers side brake line now. Slow progress for sure.
The wagenwest kit is really a no brainer for the price and fitment. Really really easy and nice setup. Would only recommend different if looking to really dial in a track setup.
Couple pics
PostPosted: Wed Apr 08, 2026 7:31 pm    Post subject: Reply with quote
Really cool with the GTS intake, though having a more generic compresor cover would have made it a bit easier to rotate it around, the reason i swapped to 951 compressor housing Its really a huge casting with the built in bov, very modern for its day in that sense.
I think i had a look at that kit, the balance is a bit wonky, and pushes the bias rearwards quite a bit, which i didnt want. But since you do the F/R+bias valve that is not an issue. Maybe its because they do aircooled stuff Nice that there is a kit out there at least, not much to chose from if you dont want or have time to do stuff yourself. For the carrera discs it might work depending on the caliper design, if i remember correctly all measurments are identical bar the outer rotor surface which is 3mm further out, and of course the inner air channels that are much larger.
Fun to follow the build, not so many 931 build out there these days!
PostPosted: Thu Apr 09, 2026 3:00 am    Post subject: Reply with quote
Damn, I need to make one of those intakes...
Mclaren924
PostPosted: Thu Apr 09, 2026 5:22 am    Post subject: Reply with quote
The intake is from mittelmotor and is high quality, going to get it 3d scanned by a buddy of mine with a very nice scanner. Was tempted to make one myself but there's no way to replicate the factory looking finish like this does.
The 951 housing was something I brought up to my turbo builder and he was firm with idea of using machined out stock housing, the exact reasons why truthfully went in one ear and out the other. I think it was a slower spool time and less efficient but I really could be wrong there. Going to have to push the steering rack mounts back half an inch on the crossmember and do some cutting and welding to the coldside inlet. I think also he has a specific turbine setup he mills for and uses and to put a 951 inlet throws a wrench in this I think more specifically the inducer is shorter on a 951 setup? Will take a look in the next couple weeks first hand as I also have a 88 951S were doing headstuds and cometic and boost controller on. Nothing too crazy
The proportioning is def a little wonky on the wagenwest kit, truthfully I was imagining anybody going to such effort already planning to add one as getting the right bias with just piston choice alone is a nightmare unless you have deep pockets.
A little sad to see how quiet the board has been recently. I'm sure this isn't the only 931 being sent to the moon right now but it sure feels like it.
Got front and rear brake lines routed yesterday. Time to mount proportioning valve and rear lines. Hopefully get all this knocked out today.
PostPosted: Thu Apr 09, 2026 5:21 pm    Post subject: Reply with quote
Maybe you should have a talk with the guy that recreated and cast all the GTS specific parts for his rally car, it was cheaper than buying them from germany. I can send you his contact details if you want, see some pics from the process.
Im not sure how Simon thoughts were going there, maybe he machines it larger than its possible to do with the 951 housing, im not sure. The 951 is pressure die cast so very light and thin.
There are actually some 931 projects going on here and there, there are a few guys i have contact with that searched me up for discussing performance builds. Since the FB groups are really awful to keep any long discussion ongoing. Sadly with the lack of forum activity there arent any collection of car build threads anymore.
PostPosted: Thu Apr 09, 2026 5:25 pm    Post subject: Reply with quote
Oh btw, could you measure the GTS inlet length if you have time? Good reference data to have to understand their intentions.
Heres a pic from my intercooler thread:
PostPosted: Thu Apr 09, 2026 8:50 pm    Post subject: Reply with quote
Yeah, I would indeed be interested in a number on a GTS intake. I assume it is still set up to use the stock S2 throttle body?
I have a stock S2 intake we lopped half of the plenum off of, with an eye to welding a new plenum with the right shape onto the stock runners... but it'd probably not look quite as nice or correct as the GTS version.
Hate to admit it, but all of my effort in the last year or so has been on cosmetics; other than a little bit of maintenance including new CVs over the weekend, I've been putting all my build money and effort into making the car pretty and special, since it's been mechanically pretty up to snuff, enough to just drive and enjoy.
Last big project was recovering the seats (see thread elsewhere), and cleaning up the paint some... next up, I still need to get around to installing the 968 wing from Marco (as well as resealing the hatch), plus 951 drip rails and 968 Cup car mirrors... but need to also hopefully today pull the POTD #77 out of winter storage - now that I think the snow's finally gone - and prep it for race in a couple of weeks! Also trying to get back to Karl's S1 931, figure out what's up with the clutch/pressure plate geometry on that, then swap out the blown turbo and cracked manifold. Thankfully,, he already has the spares, but will be a good bit of a wrench to get those going.
Mclaren924
PostPosted: Mon Apr 20, 2026 8:24 am    Post subject: Reply with quote
history is just a cycle of it repeating itself lol. so incredible that 20 years ago somebody does the same exact thing but to an even crazier degree... Any way of finding this guy cedric?
Will get on intake dimensions here soon, been slaying brake/suspension monster. The Coilovers didn't quite fit the hubs just right and had to displace some material on the back ears to allow the hub bolts to fit and there to be ample adjustment. Brake lines are all done and plumbed, currently in the process of rebuilding and then indexing rear torsion bar assembly. Very much not fun especially in a g31 car. Also face a possible issue of the coil overs bottoming out on control arms at lowered height. Will have to see once car is on the ground loaded.
Funny enough the owner of this car has also thrown the book at it interior wise, because of work being done it all remains out and will remain out for the owner to have their interior shop do carpet and install his pasha on pasha seats/door cards. We will do his new Dashbord and prototipo wheel, trying to get a GTS center console from mike for this project too so that would really help interior feel more correct.
The 968 cup mirrors actually fit pretty good, i had to drill the screw hole out a little and the base will need contour touched up to match car but overall not the worst ive seen.
It's really quite funny how "frankensteined" these cars can become with all the other models of parts that fit it or can be modified to fit. Look how far our litle toofahs have come
PostPosted: Mon Apr 20, 2026 8:53 pm    Post subject: Reply with quote
Man, it would be a trip if we could get a 3D printer file for the GTS intake... source it out to any of the online firms who can print directly to metal... the day has come...
Meanwhile Mittlemotor has it at around 1400 Euro in aluminum...
PostPosted: Tue Apr 21, 2026 5:40 pm    Post subject: Reply with quote
You can see his profile link in the last post, sadly all the pics are gone from this thread where I posted them during the build
https://www.924board.org/viewtopic.php?t=38562&postdays=0&postorder=asc&start=90
Heres a link to all those pics from the GTS rallycar build, makes the one you are working on look like a low budget project
https://drive.google.com/drive/folders/1EHdQmIvTVmSdx0qUU-6rD0LZ0N7aOLB8?usp=sharing
It could be printed in aluminium these days, but im not sure it will be cheaper than casting up a few of those considering the material involved, probably not to dissimilar to the mittlemotor prices.
Just putting the throttle on the side of a 931 manifold probably will ruin the cylinder balance a bit, especially since the plenum volume is small. But for non performance builds it probably doesnt matter that much.
Mclaren924
PostPosted: Wed Apr 22, 2026 2:22 am    Post subject: Reply with quote
Now that is a genuine Rally Race car. Wish I had the freedom to go that far with old girl here lol, unfortunately the customer want's something that is still relatively nice on street. Very hard to make that happen and get good street and good performance off road
Thank you for linking all those photos and saving them, I laugh at myself about all the random 924 posts I've read and yet there is still SO much more out there.
IMO the mittlemotor intake is pretty fairly priced WITHOUT tariffs, the amount of time it would take to make one similar from scratch would greatly outweigh the cost of the MM one. At least for me that is what I realized for this application. For a personal car I would be more inclined as the finished appearance wouldn't matter so much like it does here. Even then, that's a lottttt of tig welding lol.
There's a guy in 951 world called has brennan I think who does CF printed something or another intake for the 944 s2 951 and 968 so it is an option for sure.
I did think about welding shut or putting a plate over the original TB port and then fitting a 931 s2 TB to the side of the intake but I think this would really screw things up. 2 bar of boost would probably solve that but having the best flowing intake/head is imperative to making the same power at lower boost levels.
A little concerned about the rear end setup in this car, PO put 40mm hollow torsion bars in and that explained why it rode like a brick down the street when it first came in. I'm thinking that may be way too stiff for a rally setup even with a pretty soft rear coilover setup with reservoirs.
Also opinion on refinishing spring plates, cerakote or have replated? Worried about cerakote putting too much material on them and causing issues.
PostPosted: Wed Apr 22, 2026 3:23 am    Post subject: Reply with quote
I would have the spring plates replated, for sure.
Re: the torsion bars - you sure 'bout that size? 34mm hollow were the largest once available (no longer), we have them on the #77. 30mm are the largest now available... so you're probably dealing with those.
And yeah, that's for sure more a road course/track size... but you could probably sell those to a racer no problem, swapping to a lighter size!
PostPosted: Wed Apr 22, 2026 3:46 am    Post subject: Reply with quote
Magnus ratrod is doing something like 420-440hp on the std intake setup, so do the Italian one if you remember that episode, std intake will be just fine for this type of use, the long runners helps the low end aswell. Though the GTS looks better for sure, have you had the time to measure it? Lenght and diameter would be very interesting.
The crazy thing about that GTS build is that they chose the 924GTS platform since it was so much cheaper than other historic cars like Ford escorts etc, even though the recast every single aluminum bit, historic racing and rallying is a different world, and why mittlemotor and similar have rates that fit that world
Nicer dampers can often handle stiffer springs better, and be decently comfortable. Double check whats actually in there
Page 5 of 6
