Karlio
Posted: Fri Nov 14, 2025 6:07 am Post subject: Maximum block decking |
Any thoughts on what the maximum that an N/A block can be decked before it becomes an interference engine?
A previous race engine i done had 0.5mm but i want to go a bit more adventurous |
daniel
Posted: Fri Nov 14, 2025 5:18 pm Post subject: |
Have you considered a thinner head gasket (cometic) _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Fri Nov 14, 2025 6:19 pm Post subject: |
I assume you run some other cam than the orignal one, so I think the only way is to measure what you have clearance wise and go from there. _________________ 1980 924 Turbo
Karlio
Posted: Sat Nov 15, 2025 2:05 am Post subject: |
| Yep running a modified Newman cam 290 deg duration with standard lift. Cometic 0.5 fitted as standard on the race car |
Posted: Mon Nov 17, 2025 1:41 am Post subject: |
1.5 mm is fine. probably 2 also.
Don't get the non interference thing.... 90%of all engines are interference. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
