Posted: Wed Oct 01, 2025 5:08 pm Post subject: |
| Mclaren924 wrote: | | Cedric I believe the exact specs are a 47,4 mm compressor wheel inlet, with a 66mm compressor wheel outlet that winds up being 72mm with the extended tip. Ultimately I'm not a turbo genius by any shape or form, the main constraints with turbo choice was a relatively bolt in option. The customer was actually wanting a 8ar housing from a gts byt Simon informed us they are very hard to source and could be a long wait as well as they are quite laggy compared to the setup he has spec'd for us. If this car made 300 wheel with 91 on a dyno, the customer would be ecstatic and so would I. With that also in mind, a bigger less responsive turbo was ruled out. I'm very confident that this car will be an absolute thrill to drive and has room for more power if E85 was ever brought to the table as an option. |
Then he have done some machining to fit that wheel, it will probably work very well. I dont think the 8cm2 housing would be necessary either, the better the compressor efficiency the farther you can use a certain size turbine housing, since it will need less drive power to achieve the same boost and flow. The limiting factor would probably be the 91 fuel which sucks quite a bit, be sure to have good intercooling. E85 on the other hand would enable lots of sillyness  _________________ 1980 924 Turbo
Posted: Wed Oct 01, 2025 5:27 pm Post subject: |
| Mclaren924 wrote: | Sorry for lack of updates, have had a martini car getting a complete mechanical/electrical restoration and it has needed basically everything gone through. It could be a 5 page thread of me just posting on that car, fixing others peoples mistakes is always 2x worse than fixing a mechanical failure.
Not much has been done to 931 project as it just got it dropped off to paint a few days ago and machine shop is supposedly getting everything done by next week. Currently not much to be done as I don't have the chassis or the motor. I do have the trans and TT so have been getting that all assembled and mocked up to make sure it's all there and will be no issue come install time. Currently toying around with short shifter. 100% credit to Lizard for original design and Ideola for posting the specs and having a good thread talking about it.
https://www.924board.org/viewtopic.php?t=33456
Making a 3d printed mock up right now out of some cheap abs to test out the throw. Will print a Carbon Fiber nylon version after I get the design to tolerance and let a buddy test it out in his s1 turbo and see how he likes it. Really aiming for just an improvement of the stock to make spirited street driving more enjoyable. If we like the feel and how it drives, I'll machine one up and go from there.
On an engine related note, customer was interested in doing a lightweight flywheel and pp setup. I know the pp is an easy one to find as its a 915 part and somebody is making those for sure. The lightweight flywheel on other hand I'm not too sure is being made as an aftermarket part. Apparently the s2 flywheel is a good bit lighter? Will have to weigh some tomorrow to confirm this. I'm sure it's in this forum somewhere too lol. |
Ive ran that shifter for years, it works well, but I had some interference issues with the body insulation if i remember correctly. I spaced down the front bushing for the shifter to move the shift rod down slightly which solved that issue.
Regarding the flywheel, they are all very different , aswell as the different specific pressure plates they fit to(there are some combinations that were on these), so the easiest way would be to just shave off some weight of the current flywheel, the S1 wheel have some meat that could easily be removed, i even have on of those made years ago that I never used
Mclaren924
Joined: 13 Oct 2021 Posts: 265 Location: Oceanside CA
Posted: Wed Oct 29, 2025 2:10 am Post subject: |
You are right Ciprian, I believe the housing was indeed machined to accommodate bigger wheel.
After talking with the customer, we just opted for a stock s1 flywheel. Going to take a page out of your book and stick with what the engines design benefits and just feed it more boost and keep rpm down. Ultimately the head is completely stock minus an adjustable cam pulley so the top end couldn't handle extreme abuse either. We may run a set of stiffer springs that mittlemotor has.
Just got the centerforce pressure plate and the flywheel and morghens crank pully dropped off to machine shop and they should have it all balanced and ready to go for us tomorrow.
The body shop has the engine bay almost completely stripped down and has a good paint match ready to go, hoping that's done this week too. We shall see _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Mclaren924
Posted: Fri Nov 21, 2025 3:20 pm Post subject: |
Sorry for sparse updates, not from lack of desire. Machine shop just finished the machine work on monday. So much for it being done 3 weeks ago lmfao.
In all they decked both surfaces, replaced all valve guides and reground valve seats as well as ground old valve mating surfaces for a good seal. The bore was punched out to match the 88mm piston and the crank was line bored to help fix distortion caused by ARP main studs. DO NOT install main studs and go on your merry way, you absolutely need machine work to help true up the crank journals again. Lastly they polished the crank and checked the head and block for cracks, and balanced the whole rotating assembly including flywheel/PP and crank pulley. Took about 3 months and was about 2k USD down here in socal. Unfortunately this is the fastest and cheapest it gets while still getting quality work.
Speaking of which I mic'd out all the journals and all the main bearings were around .002 of clearance, went to check rod bearing clearance and it looks like my 1.5-2.4 in dial bore gauge shit the bed on me so I was stuck using the T style bore gauges and got an average of .0025 for the first rod bearing I tried. Will measure all 4 again tomorrow when my snap on guy comes by with a new dial bore gauge, I'm pretty sure it is going to be fine but I had slight concerns that the arp2000 rod bolts calling for 50 ft lbs may distort the bearing tolerances without any machining. So far it seems I was wrong in that concern as like I said, right around .0025 clearance. Double checked rod stretch and was within desired .005-.006 spec. Getting a real dial gauge in there tomorrow will put me at ease. Tomorrow will get rods squared away if everything is good measurement wise then will setup the rings. JE leaves the rings long and gives you a bunch of different applications and their desired ring gap so will have lots of fiddling to do with that. Will also have to check block bore is good for piston but I'm hoping the machine shop could handle that...
Will post more updates tomorrow or day after and what's going on with the build. Apparently chassis comes back on Tuesday from having engine bay painted.
Besides this I had a super weird and ill timed issue with another customer car, was a 77 martini we did a motor and basically complete mechanical/electrical overhaul for. The car left with 150 psi on all 4 cylinders and a good idle with lots of power, no leaking injectors and a new fuel filter/ a good FD swapped on as old one was bad. The plugs were swapped after initial tune up and run in was done and it never ran without an AFR gauge on it and was always ran around 14 area. It did have the classis hard start when left to sit hot for hour or so.
He comes back monday to try and fix hot start and I pull plug 1 to see what fuel mixture looks like and it is covered in chunked up carbon. Wtf I say, run comp test and down to 90 on all 4 and all 4 have carbon all over plugs. I scope all 4 and there's insane carbon build up everywhere. Pull the motor out and the entire valve seat/head/pistons are caked in it. Pull everything apart and no signs of any mechanical damage. Engine goes back in tomorrow and will run through the entire fuel system again from injectors to pump. The tank in the car is horribly rusty and despite emptying, shop vaccing, flushing, and repeating twice, I think it is still contaminating the fuel system somehow. I'm not sure how this much carbon could build up in 1500 miles or so, I think of maybe the FD is directing too much fuel to injectors, cold start stuck open all the time, all 4 injectors leaking or stuck open(I highly doubt as they're new). would love some thoughts on this side tangent
https://imgur.com/vhLyrzB
https://imgur.com/N1PP9ih
only reason no 1 is clean is because we just cleaned it out _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Mclaren924
Posted: Tue Nov 25, 2025 3:30 pm Post subject: |
Well the 77 martini car was bad news, about a 1/4 pound of rust was scraped out from bottom fuel bowl and there's way more. Words can't even describe how bad it is, just watch the video. Owner said he had the tank redone and coated 10 years ago and it has since failed and been stirred up or aggravated by the cars awakening from it's 4 year slumber. He will be going with a new tank, strainer, filter, and sender. May wind up replacing accumulator too if its really nasty. Will need to blow through all the lines and hope the kjet parts didn't suffer.
https://imgur.com/uDqivpW
https://imgur.com/gacM2Rq
The 931 motor is going together nicely. Have been so dammed busy moving houses and finishing moving into the shop, it has been hard to get all my ducks in a row. Finally got the crank in, ring gap all set and confirmed piston to wall clearance and bearing clearances were good. Can post exact numbers next time I'm in shop, just need to get the pistons installed on the rods and then slipped in the bores and the bottom end is assembled. Chassis will be back from paint this coming Monday and then it's going to get going fast from there!
Also just got in the mittlemotor adjustable cam pulley and their valve springs, all in all $550 or so. $180 were tariffs, thanks Donnie
Even so, that's a pretty good price for all 8 inner and outer valve springs plus the cam gear. _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Posted: Tue Nov 25, 2025 6:58 pm Post subject: |
For the cam pulley theres plenty of VW wheels available aswell, i run one from a vw tuner shop
I had to rebore the rods, but they where used std rods with ARP screws, need to double check how hard those where torqued.
Do a fuel balance test on that martini, run the injectors in bottles an measure the weight, should be within a few percent. _________________ 1980 924 Turbo
Mclaren924
Posted: Sun Nov 30, 2025 12:41 pm Post subject: |
Cedric do you mean the old group buy arp hardware meant for 924 rods or the alfa variants that are very similar? God I read these forum posts and a part of me feels like I missed the 924 golden age with Ideola running his shop and the community being so active. Another part of me feels like this is the golden age with kits like ciprians being sold and all the other awesome support the 924 has been getting and how much technology has advanced. Also how we benefit from all their trials and tribulations.
I was a little concerned what the rods were going to measure out to being they're aftermarket and the crank wasn't turned specifically for them but they would up being perfect, same with side clearance between piston and journal. Really nice product from Pauter.
Good news about the VW cam pulley, the mittlemotor one was actually fairly priced and I was mostly interested to see if what came with their valve set for 180 Euros. Their customer service wasn't great which is probably my fault for being on wrong side of planet and not speaking german lol. Am very happy with their complete inner and outer set for the price, currently not a lot of options for springs that don't break the bank.
Maybe I'm wrong but as far as I know, please correct me if so. There's nobody making off the shelf performance valve springs for these cars? Most people wind up redoing the whole setup with different lifters, lash caps, and all that jazz which isn't super enticing for a street car that will never see super high rpm. Maybe you could have some custom springs made to work with stock lifters but what's the point of only doing part of the weight reduction...Rambling here sorry
The Martini Car will need to have all the injectors tested and the WUR recalibrated along with probably tuning the FD, really a bummer with that car. Unfortunately a tale told on here very many times too, as the saying goes.There's no such thing as a cheap porsche.
I just got back in the shop from thanksgiving seeing family and waiting till monday to call JE to see if these pistons are bi directional or not. There is no markings on them or any statement in the instructions, as well as the ring orientation can be set based on the piston correctly with it in both directions. 99% sure it does not matter but finding out after the head and turbo kit was on would really suck. Will get the head put back together tonight and tomorrow so I can put it all together once I get the word from JE. IF one of you fine gentleman who installed these pistons before and want to save me some waiting, i'd be very thankful. Until then, thanks for reading my late night ramblings and will update again soon. Hopefully get chassis on monday...
Joined: 29 Jul 2001 Posts: 9069 Location: Royal Oak, MI, USA
Posted: Sun Nov 30, 2025 10:43 pm Post subject: |
Re: valve springs - I went with new stock original Porsche parts for my builds (NA racecar - ITB and HP motors)... nice that they're now available as such!
On my GSXR motors (in the prototype), my pro engine builder (best in the country, many Runoffs wins) has stated that factory Suzuki ones are the best, every other aftermarket spring he's broken. I've had aftermarket ones break on the track. Just don't have the same quality control as factory.
So I don't know if that applies to the Porsche parts... but I'd bet it does.
We just shimmed our stock springs up, is all... per Dima's recommendation for the HP cam. _________________ Vaughan Scott
Mclaren924
Posted: Mon Dec 01, 2025 3:46 am Post subject: |
This was a concern I had about the springs, I've seen a lot of heartbreak first hand with some of my chevy customers when they get supplied wrong or cheap springs and things fail badly. I plan on running these mittlemotor springs in a personal engine and will see how they fair. It's not worth the risk trying them in a customer build and having to pull a head because of a part failure due to manufacturing standards being bad. Pulling a 924 head would be one thing, pulling a 931 head off in car would be a whole different level of hurt.
This customers original springs had very similar rates compared to a new porsche one I supplied my machine shop to test with so I have no concerns reusing old ones. Especially being this is a street car.
In your case 924racr, if its a 931 head. Do you remove all the rotowashers and shim up the missing depth there too or do you shim under them? Similar question for NA's. I think I've heard you mention this before on the board too.
Aside from that I Just got done cleaning up some casting marks on the intake ports and matching the head to the intake gasket, not going to touch anything inside the port as A the valve guides already in there and B without a flow bench or a lifetime of experience porting heads (I have neither), it's really not a wise idea to mess with ports. Also I think it's probably pointless doing a bunch of port work with a stock manifold on it, just spend the money to do a much better intake and I think then maybe extensive port work to match the new intake may make sense. This is at least what I gained from reading mike931's custom head work build. Not to say he didn't make huge improvements in flow over a stock 931 because he without a doubt did, the effort and money to achieve that would probably be better spent on the intake. Which he also denotes the stock intake being a huge issue with porting and trying to improve the 931 flow.
I am debating making a gts/gtr intake manifold setup and having it tested on the dyno vs the stock intake when this car goes to get tuned. Would be really interesting to see real life results of stock vs gts/gtr style and no port work and then of course ported in junction with new style intake. Mike if you're reading this  _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Posted: Mon Dec 01, 2025 4:45 am Post subject: |
In our case - no, NA head not a 931 head. Pretty sure the shims were under the lower seats, seems like the only thing that'd make sense.
I do some day want to make up a GTR style intake for my 931 - since it's running the 951 IC. I have a sectioned stock 931 intake which just needs rework... but it's been a super-low priority task anyway... especially since I've been working on the interior and cosmetics instead! LOL _________________ Vaughan Scott
Posted: Mon Dec 01, 2025 6:27 pm Post subject: |
| Mclaren924 wrote: | This was a concern I had about the springs, I've seen a lot of heartbreak first hand with some of my chevy customers when they get supplied wrong or cheap springs and things fail badly. I plan on running these mittlemotor springs in a personal engine and will see how they fair. It's not worth the risk trying them in a customer build and having to pull a head because of a part failure due to manufacturing standards being bad. Pulling a 924 head would be one thing, pulling a 931 head off in car would be a whole different level of hurt.
I am debating making a gts/gtr intake manifold setup and having it tested on the dyno vs the stock intake when this car goes to get tuned. Would be really interesting to see real life results of stock vs gts/gtr style and no port work and then of course ported in junction with new style intake. Mike if you're reading this  |
Theres nothing wrong with the intake if you have a low reving engine and need some intake lenght, the matching of the runners to the head wasnt great on mine, so i made them match up better. I think it definitely could be worth doing a touch up of the ports, just smoothing out the transition to the valve area where the ugly machining is due to the seat, especially the innter radius which isnt a radius in form due to said machining. For a high rev engine of course a shorter runner manifold could helpt. But with the efficiency turbos that are available these days there so much that can be done with boost that the engine gets less important as long as it stays together
For a 300hp engine though you probably dont need to do to much. port match and touch up ports, else keep stuff standard to start with and keep the rev limit in the region of the std one.
I used the old group buy ARPs, and yeah the community was a completely different world back then(the same for the local 924/944 community), sadly its nothing like it anymore, and its the case for many car communities due to FB and others killing it off.
Regarding the Mittlemotors customer service i have the same experience, not great, but eventually it gets sorted. _________________ 1980 924 Turbo
Mclaren924
Posted: Tue Dec 02, 2025 3:03 pm Post subject: |
| 924RACR wrote: | In our case - no, NA head not a 931 head. Pretty sure the shims were under the lower seats, seems like the only thing that'd make sense.
I do some day want to make up a GTR style intake for my 931 - since it's running the 951 IC. I have a sectioned stock 931 intake which just needs rework... but it's been a super-low priority task anyway... especially since I've been working on the interior and cosmetics instead! LOL |
It's nice to me to go back and forth from interior to mechanical to fabrication and so on, stuck in one for too long makes it less enjoyable for me, thankfully I get a pretty wide variety of stuff in here so I'm never stuck doing one thing lol. I'm sure this will make a little improvement.
Cedric I may have misspoken about the intake in my late night ramblings, it isn't persay bad and in need of replacement right away. You are spot on how modern turbo's have cut away the need for very high efficient head flow being a requirement for making power, although it certainly is a big part in many other situations. I meant more per say that the cost of porting a stock head to an extreme level is probably pointless without a more efficient manifold to boot and then porting them together. I'm sure with enough boost and e85 you could squeeze 500+ out of a stock manifold. Safe has already pretty much proven this, and he did it on a stock bottom end as well correct?
The port's on this 931 head were full of rough casting marks and the ports were pretty poorly matched as well between the intake and head and of course the gasket was nowhere near a perfect fit lol. I finished porting and polishing on sunday morning and i'm just getting all the aluminum dust out of my nose monday night lol.
Yes the rev limit will be kept standard or very close, the head is bone stock and the juice isn't worth the squeeze after 6500 rpm
Picking car up tomorrow from paint shop and ball will start rolling pretty fast on this build again. JE told me today that pistons do not have an orientation and can go either way so got those installed and head fastened down. Getting the valve lash set now and the previous shop put this head together with the following tappets, 2 with no marks, 2 with 1 mark, 3 with 2 marks, I'm guessing whoever did their head work didn't offset grind the top of the valves to make them an equal setup, not that you need to do that for it to run. Just makes shimming buckets a total PITA if you have to swap the cam in an out a bunch of times changing adjuster screws. I just got it together for the first time and all but 2 of the intake valves will shim with a no mark bucket. The 2 that wont could probably be ran but I want a good amount of threads protruding from both sides for a solid fit and they're definitely maxxed out _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Posted: Tue Dec 02, 2025 6:40 pm Post subject: |
| Mclaren924 wrote: | | 924RACR wrote: | In our case - no, NA head not a 931 head. Pretty sure the shims were under the lower seats, seems like the only thing that'd make sense.
Picking car up tomorrow from paint shop and ball will start rolling pretty fast on this build again. JE told me today that pistons do not have an orientation and can go either way so got those installed and head fastened down. Getting the valve lash set now and the previous shop put this head together with the following tappets, 2 with no marks, 2 with 1 mark, 3 with 2 marks, I'm guessing whoever did their head work didn't offset grind the top of the valves to make them an equal setup, not that you need to do that for it to run. Just makes shimming buckets a total PITA if you have to swap the cam in an out a bunch of times changing adjuster screws. I just got it together for the first time and all but 2 of the intake valves will shim with a no mark bucket. The 2 that wont could probably be ran but I want a good amount of threads protruding from both sides for a solid fit and they're definitely maxxed out |
The intake is more about usable RPM target than HP, if you want to make a 7500rpm engine with quite a bit more aggressive cams it gets much more important to get the ports and intake length tuned for it. Something like Joakims 450hp engine with significant head work and intake is a wildly different engine with an impressive rev range and power at low boost, but at a high cost for sure ! Making the power with boost only is simpler, but has some drawbacks, it took a little while to spool the turbo all the way to 2bar/29psi in Magnus car, but it was fun to drive for sure
Its good to have a bunch of spare valve buckets to take the adjuster screws from when you stand there and try to get the adjuster right and they "bottom out"
I checked the intake/port misalignment on a friends n/a and it was significantly better my 931. Maybe the small volume 931 had a less tuned in production run, I couldnt use the gasket it wouldnt have been good, so I used cereal box carboard and a small round hammer to make patterns for where the runners actually were and matched on the port side. _________________ 1980 924 Turbo
Mclaren924
Posted: Sun Dec 28, 2025 7:52 am Post subject: |
What a crazy month it has been! Happy holidays everyone and time for some updates!
The pistons were machined incorrectly by JE, there are actually two other sets of #### up pistons sitting on EBS'S shelf that have same exact issue as mine. For whatever reason EBS decided to spec the piston to have "Custom" work done to it by milling down the pin boss area to fit the connecting rod they chose. Ultimately JE missed the custom work part and shipped them with the standard pin boss they have for the part, resulting in my rods not fitting.
First and foremost I blame myself for one, not catching this in my initial CQ check when they first arrived, I neglected to check pinboss diameter and could have caught it all before the machine shop. Ultimately I didn't and the block got punched out to fit those pistons meaning there's no getting a different piston or anything like that. Especially with the coating being ran on these pistons, they never come to an exact size as listed.
This left me with two options. either send the pistons back to JE on my dime both ways and have them take weeks to correct pinboss, or I find another set of rods that will work. Long story short is God was watching and threw me a bone, 2 days later another 931 enthusiast posts on FB essentially the same set of JE pistons and PAuter rods for sale for 30% under retail. The rods wound up being the exact same rod but with a .100 thinner small end with and weight was almost exact. Truly couldn't have gotten luckier with the timing, Jim if you're reading this. Thank you again buddy.
I will say i'm not super pleased with EBS either, it seems super convoluted to have JE make modifications to the pinboss when they have rods and piston combos that fit without issue. Essentially, the custom rods they spec'd for me could have worked on the other set of pistons I obtained as those pistons had a wider pin boss.... Meanwhile my original pistons will fit the second sets rods with no issue... To me that just seems like a recipe for a ####, why not just spec a set of known fitting and working parts instead of having custom stuff done. Sorry If I lost you here, will post the rod and piston specs down below.
My Pistons and rods
The set I got to fix my issue
With the piston and rod debacle behind me, the motor went together pretty smoothly. Customer has gone back and forth so many times on the front mount setup vs top mount, finally have him set for a front mount intercooler and GTS style intake. May wind up making our own replica because to import the mittlemotor one, it would be almost 5k all said and done. I have thought about buying one in person when I fly over to germany in a 3-4 weeks and just shiping it to myself... Negate VAT and the orange man tarrif all at once. Currently just has a s2 intake to keep it all covered up. A lot of the bracketry and some covers are off being powder coated as well.
Mclaren924
Posted: Sun Mar 22, 2026 3:21 am Post subject: |
*Tap* Tap* Is this thing still live?
Sorry for the long hiatus on the thread/car. I don't like just sharing bad news and truthfully I was very frustrated.
The car is going GTS intake with a 3" front mount and the CSF 944 radiator and fan combo wit a 944 coolant tank. Going to do a set of coil overs with option for good amount of lift from a company called flatout suspension, they are a rally off road race style coil over with remote reservoirs. Will be doing the high strung front arms with 924S front and rear hubs and aluminum rear trailing arms and the wagon west 944 wilwood kit. Not sure on rotors or pads yet. Will try the stock 931 master and booster with an added proportioning valve to hopefully avoid switching booster and master as the customer just had those replaced before he came to me. Ultimately if we need to we will. Finish off the running gear and do poly bushings all the way around with reindexed rear torsion bars to match lift.
Going to replace the stock WG with a 40 mm tial one located similarly to stock but with an easier service position and a much stronger mount. I find that about every other 931 I work on or see had damaged or broken wastegate mounts as well as turbo mounts.
Enough blabbing about what we're planning on doing and time to blab about what's been done.
The engine was completely dressed and ready to install and a little voice in my head said to check leadown and long story short it was 15% in 1-3 and 50% in 4. The machine shop guaranteed they vacuum checked it before they left so I didn't leak down test it as soon as I put the head on. That was a learning lesson. Strip the whole #### down and take back to same machine shop to rectify the 4 exhaust valves not seating. Takes them 2 weeks of me calling every other day, I go to pick it up and the guy accuses me of giving him a different cylinder head... Long story short is I picked up all my shit and left, took the head straight to S-tec in Stanton California and they had it turned around in 3 days. all 4 exhaust valve seats and guides had to be redone because they weren't cut concentrically and the cherry on top was all the valves had deep gouging right on the valve stem seal face from where they were chucked in something and either spun in the collet or just got chucked in a bench vise.
Engine has been redressed, turbo back on and in the car finally! Centerforce clutch, pressure plate and flywheel also installed with bellhousing to confirm fitment and mock up WG. The Cooling pack has been mounted and top mount brackets have been designed and will be machined in coming weeks. Currently just have an nylon cf printed part doing the job. The intercooler with the bottom outlet requires a lot of rework, for starters the wiring harness must go through the front tub now and along the outside of front tub as there is no space to route in stock location. The AC condenser and dryer makes this much trickier of a setup and so does the stock turbo location. The condenser can thankfully move around a bit as we have gone to fixed headlights and can just have some custom ac lines made. The turbo location is a rear problem with a standard inlet/outlet intercooler. For us we find the best option is rotate the cold side turbo housing... Maybe we will be
the first to do this in a 931? The fresh air inlet will have to be cut and rewelded to a straighter angle so we can use the stock style brake duct inlets as a turbo/oil cooler inlet. The steering rack will need set back by about 20-25mm onto the crossmember so we can clear the turbo cold air outlet.
The fixed headlight the customer chose were from Marco Antonio, pretty pricey and all the assembly must be done by me, the brackets that come with the kit were bent incorrectly and truthfully were extremely rough and crude. All 4 of the brackets were completely wrong in shape and to correct would have been a really not fun task. Ultimately I just opted to make my own brackets for it, we still have to mount them to the bucket anyways as the original brackets weren't setup for the buckets either. Truthfully I may just wind up telling my customer to bite the bullet and source the pair from mittlemotor, they come preassembled with good lenses, and nice cnc brackets. They are like 1100 euro before taxes and tariff though, will probably be double marcos prices when done. The cup style mirrors supplied by marco are a much better fit but still required modification to make bolt on.
Hope to be much more active in the coming weeks as more parts start showing up and we start getting closer to being done. Goal currently is make it to air and water in a month and a few days. The grind starts now.
Besides that, I cheated on you guys and we've had a 996 in the shop, so much more enjoyable to work on then the 924 or the 931. That quickly changed when it went from a tran out IMS/clutch job to an engine and trans out job to fix oil leaks and then I pull the ims bearing and its full of chain tensioner material, gulp. Main chain guide is smoked and wholeeeee thing gets stripped, now I wish I was building or tearing down 931/924 engines lol. I'll leave a photo at end, I think porsche left out a couple fasteners and parts, they could have easily fit some more in this 5 chain m96....####. Word of advice if you read this, don't buy any 996 that hasn't had a complete motor overhaul unless your buying it at a a price and with the intentions to do a whole motor. Even when the IMS boogeyman doesn't get you, it's friend the chain tensioner, ramps, guides, will get you lol. If bore scoring hasn't already
https://imgur.com/kjnsh0T
https://imgur.com/wdZEokI
https://imgur.com/FUUYw3T
https://imgur.com/Q3Wbhkx
https://imgur.com/5zpsuAn
https://imgur.com/NT9X4h9
https://imgur.com/y6u8SaD
https://imgur.com/LQ9gRJF
[img]https://i.imgur.com/nwW2frI.png?1[/img]
