mrborrie
Posted: Mon Aug 09, 2021 10:16 pm Post subject: Jump wire went wrong |
Long story short, i jumped pin 15 and pin 1 instead of pin 30 and 87.
From my understanding the pinout is followed:
Terminal Number - Connection
30 - Permanent battery live
31 - Earth
1 or 31b - Coil negative
15 - Switched 'Ignition on ' voltage
87 - Output to fuel pump
So i connected the coil negativ (green wire) with the switched ignition on.
Apart from having to open up the entire loom what else should i look out for replacing / fixing.
Im pretty pissed at myelf but happy the car did not went up in flames, the wires are toast as i started with the loom already but could have been worse _________________ 760 Turbo |Volvo 360 cup|Volvo XC90 04|Porsche 986S|Porsche 924 79| |
Posted: Tue Aug 10, 2021 6:05 am Post subject: |
Take the loom out and replace the affected wires completely or at least re-insulate them by heat shrink tubes. You probably damaged their insulation. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Tue Aug 10, 2021 6:48 am Post subject: |
Did something happen? Smoke? _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
mrborrie
Posted: Tue Aug 10, 2021 5:25 pm Post subject: |
Yes lots of smoke, i'm such an idiot for walking away to look for my volt meter, contact was on for a minute or so witoud my precence.
Took off all the wraper from the loom to check the individial wires and the black and green wire are affected. I can narrow it down to 2 connectors that pop out the relaybox/fusebox.
Some nearby wires have lost part of the insulation so there is some work to do for sure. _________________ 760 Turbo |Volvo 360 cup|Volvo XC90 04|Porsche 986S|Porsche 924 79| |
Posted: Tue Aug 10, 2021 8:08 pm Post subject: |
We all make mistakes and break something once in a while..
Sounds like your on the right path to fixing it.. _________________ 80 Turbo - Slightly Modified |
mrborrie
Posted: Thu Aug 12, 2021 6:07 pm Post subject: |
So i got most of the wirepulled back to the enginebay ready for replacing.
I would like to replace the connectorspins in the connector. but they look very small
Does anyone know the pins used in the connector and where to buy these new?
Talking about the pins in this connector
Posted: Thu Aug 12, 2021 7:51 pm Post subject: |
That looks like you left it there for a minute with wrong pins connected
I suggest replacing the whole section of the wiring loom or the whole wiring loom. _________________ Supercharger and EFI kits
mrborrie
Posted: Fri Aug 13, 2021 1:26 am Post subject: |
Epic! _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Posted: Fri Aug 13, 2021 4:45 pm Post subject: |
Well, you wont make that mistake again, that's for sure !
So now you need two things, a replacement wiring loom and an air freshner for your 924.
Ask in the buy/sell section, surely someone has a parted shell that still has the wiring attached and they would be willing to send it to you.
I would not trust the old loom at all after all this damage..you dont know what was damaged and what not.
From...ahem...experience..i can tell you that you probably fried the relay panel as well...that big plastic thing where all the looms connect....take out the connectors and inspect the individual pins...surely at least one is melted.
I have done a similar mistake once on my buddie's car...i however realised i did wrong in a matter of a second and i managed to just fry the ground wire...but the connector slot in the relay panel was damaged so i had to replace the panel. _________________ Supercharger and EFI kits
mrborrie
Posted: Tue Apr 04, 2023 5:57 am Post subject: |
I cannot believe it was this long ago already, yeah i got very upset and parked the car and lost interest until now.
Meanwhile I did buy a box full of cutup loom and a complete loom.
Last weekend i took another assessment and notices about 8 wired needed soldering and other needed just verify and clean.
I seem to have powered the minus on the coil frying the distributor electronics
For the following i like to look at a diagram to figure out where these wires should end up:
6 Pin connector: Green/white and a Green wire coming from 1 pin
Fuelrelaybox wires:
Black Relay fuel to ?
Green/white relay fuel to ?
Photo of the 6 pin connector friend and the replacement already installed (apart from the green wires)
Posted: Tue Apr 04, 2023 3:59 pm Post subject: |
Be very very careful this time, triple check everything 10 times and when you connect the battery dont stand aside ready to take pictures, stay with your hand on the terminal ready to take it off at the first sign of a short.
Maybe graze the terminal over the + of the battery before fully connecting it to see if it makes big sparks, if it does, then you have a big consumer and you've done something wrong and should not fully connect the battery. _________________ Supercharger and EFI kits
mrborrie
Posted: Mon Apr 08, 2024 3:26 am Post subject: |
I seem to have a yearly interval
So i ended up buying a loom and a box full of cut up looms last year based on the posts here.
Just a few months ago i pushed the 924 out of its parking spot to work on and after further inspection i deduced that the best route was to actully repin the wires using some wireloom from my parts out Volvo 740
Recap:
- Redid/repin multiple wiring and went over the entire loom.
- Replaced the rotor, rotorcap
- Replaced the ignition points & condenser
- Replaced the sparkplugs
- Forget to order a new coil.. maybe the 740 one works? i guess the one i have is shot.
So , back to the forum with also a question because fiddling with the wires has made some connector undone
1. White wire in the fusebox "Pin G8" it goes into connector D .. My wireloom diagrams dont show Pin G8 so no clue where in the connector D i should press it back in (multiple options are pinnened and unused
2. A tick blue wire is pinned from the+ of the coil that also leads to under the dashboard near the fusebox and is not connected. It may have been added by the PO because they are much ticker than anything else on the car. I also cannot find in the wirediagram a second wire from the coil besides the black/yellow wire that is also still on the + of the coil
Other than that i think if i have those 2 wires back in place i can retry adding the battery to the car again.
I assume my fuel pump is still dead too, what is the best way to get some fresh fuel in the fuel distributor for testing the car before tacking that
I did buy a replacement fuel pump but i had to use it on a another Volvo that needed a pump in between
mrborrie
Posted: Tue Apr 16, 2024 5:49 am Post subject: |
Tiny update: i hooked up the battery and no flames, also confirmed now the fuelpump is indeed dead and i have a new one on the way
Dumped some fuel directly in the hose for the fuel distributor but no running engine yet, i found the ground lead on the engine being almost broken too and perhaps the contactpoints i need to re-visit. ( i do get spark on them at interval)
Still unclear on the disconnected wires so they might be the culprit too. _________________ 760 Turbo |Volvo 360 cup|Volvo XC90 04|Porsche 986S|Porsche 924 79| |
Raize
Posted: Sun Apr 21, 2024 3:38 am Post subject: |
| mrborrie wrote: |
Dumped some fuel directly in the hose for the fuel distributor |
Don't do this. It won't work. The FD needs input of at least 4.5 bar pressure to function at all, it's not a carb. |
