Making adapters for Boxster brembo calipers
PostPosted: Fri Dec 29, 2023 7:42 am    Post subject: Making adapters for Boxster brembo calipers Reply with quote
Hi
Im doing a little side project while waiting for parts to finish my engine stuff. Not that im in direct need, Ive had the std brakes work well on track, and could step up a few levels in pad compound with the new power level. But instead Im doing this, mostly for fun, but also to be able to run less hardcore compounds since its also a road car, and still handle the heat.
The choice is 4 piston Boxster front calipers from the non S, they have pretty much exactly the same piston area as the original calipers, so no shift in balance. the plan is to combine them with the Carrera 3.2 discs, which are 24mm wide, instead of 20,5. That will also give some additional heat capacity. I hope i can still fit with 15" wheels with these ones, thats the plan.
Weight wise they weigh ca 3.2kg complete with pads, i couldnt weigh the std caliper since it maxed my little scale at 5kg. So even with adapters and heavier discs it will cut some weight.
Im fine tuning the fitment now, and waiting for brake discs (cost me about 65usd /each, so very reasonable. when the discs arrive i will conclude the design and order them machined.
Btw, they will be sturdy fairly heavy pieces made of steel, i dont want to rely on treads in aluminum on a track car.
Anyone else interested in a set? Could be fun to get someone else on the project
Mclaren924
PostPosted: Fri Dec 29, 2023 2:33 pm    Post subject: Re: Making adapters for Boxster brembo calipers Reply with quote
Cedric wrote:
Hi
Very interested in a set for my 77 Restoration that I want to 5 lug swap.
1979 3/5 gt clone 924- Shop Test Car
PostPosted: Fri Dec 29, 2023 6:27 pm    Post subject: Reply with quote
I need to check my disks and pads condition, if i need to replace them i'll also want a pair of adapters.
PostPosted: Sat Dec 30, 2023 11:33 pm    Post subject: Reply with quote
Work has been progressing, and protoypes has been tested, adjusted and tested again, its very small changes to get everything perfectly centered up. And I also got my 24mm discs, so i could sort out the final measurments.
Pretty happy with the location of the caliper now, so I think im gonna work a bit on the design to prepare for ordering of the steel ones.
The thicker discs has significantly more flow are in the cooling ducts, this looks vert promising for the heat management.
20,5 vs 24mm disc
difference in cooling channels
with the thicker disc installed
Joma
PostPosted: Sun Dec 31, 2023 5:34 am    Post subject: Reply with quote
sign me up
i got a set of calipers left over from my 987 that i upgraded to 330mm.
any plans for the rear brakes?
924 80 with 931 S2 engine and efi
PostPosted: Sun Dec 31, 2023 7:52 pm    Post subject: Reply with quote
Joma wrote:
sign me up
Just had a quick google and the base Cayman seems to have the same calipers as the base 986 Boxster, so it should work.
Regarding the rear brakes i have no plans, theres much less thermal load on them, would be nice to shed some weight though, but finding a fancier caliper with such a small caliper area is not so easy. Balance is important for me since im performance oriented, dont want to make the braking worse than the std system:) a re route of the braking system to f/r and reducer valve for the rear would of course make it easier to find calipers, but i want to keep it simple.
Caliper part numbers:
986351422
986351421
PostPosted: Wed Jan 03, 2024 11:16 pm    Post subject: Reply with quote
Isn't there one or two bolt on 944/968/Boxster Brembo solutions for the rear of a 931? I can't recall exactly without searching, but it was always the front where mounting needed a 944 hub or mounting adapters.
But, if you have lost decent weight out of the rear, the stock rear caliper easily locks up before the fronts on my car.....especially trail braking which once used to the movement helps pivot the car in sharper corners.
PostPosted: Thu Jan 04, 2024 12:08 am    Post subject: Reply with quote
I haven't found much on the rear that have close to the right piston area, almost every caliper has to much of it, maybe if i used a different front caliper. The boxster/cayman one is the same area as the std caliper up front, which is one of the reasons i chose it, and the compact size. 2 piston 36mm Brembos from an impreza sti would have the same area though as the std ones But its not something i will look at now. At the moment im finalising the order of two sets, one for me and a spare set for someone that wants to try them
I found std brake bias to work very well, and i always trail brake deep to the apex, Hence i want to keep the balance as it is and not shift it, according to logs my braking looks really good compared to other similar track cars,. i hope it will continue like that
barnwerks
PostPosted: Thu Jan 04, 2024 3:49 am    Post subject: Reply with quote
I am also interested in a set of these adapters. Do you have an estimate of cost? Are you willing to ship to US?
PostPosted: Thu Jan 25, 2024 7:43 pm    Post subject: Reply with quote
The parts just arrived from machining, made in steel with nickel plating. Everything seem to line up great. So time to gets some proper pads and put everything together. The fitment with cookie cutters 15" for example still needs to be checked. I have some 15" BBS wheels around aswell that i could try. With some help of a friend we did some half decent FEM calculations, and updated the design to be sure they outlast me and the car
The spare set might be up for grabs if someone have plans to try this mod, and could drive their car sooner than i can drive mine
PostPosted: Thu Jan 25, 2024 11:43 pm    Post subject: Reply with quote
These look amazing! And really cool with those cutouts in the midle.
PostPosted: Fri Jan 26, 2024 12:04 am    Post subject: Reply with quote
It was a good way to cut some weight, but I also did it for them to look cool just for fun
PostPosted: Fri Jan 26, 2024 3:23 am    Post subject: Reply with quote
Sooo nice!! This is why I come here. There are more of us out there
Really nicely done. They look wicked!
Joma
PostPosted: Sat Jan 27, 2024 8:54 pm    Post subject: Reply with quote
They look really nice.
i still want them, but i will be a while before i can test fit them
currently working on the outside of the car.
and need to have the callipers rebuild and repainted.
so i want them but cant immediately fit them
PostPosted: Sun Jan 28, 2024 8:05 am    Post subject: Reply with quote
What wheels do you intend to use?
Today I had some wheel fitting tryout, i tried 15" BBS mahle, 16" Fuchs (Maxilite), 16" D90. The BBS wheels and especially D90s had plenty of room. the Fuchs were much tighter now that i moved the caliper out to accommodate the wider brake disc, but it fits, i just have to relocate the balancing weights to be sure they doesnt touch
