Welding the Battey box Area
924gtracer
PostPosted: Tue Nov 21, 2023 9:51 am    Post subject: Welding the Battey box Area Reply with quote
I wasn't sure what to title this. So as I will be cataloging my recent 924 Turbo exploits shortly. I now have 4 in my Shop...anyway I have been working on the while I wait the titles before I really jump on these projects with more money. I have building list of repairs and such for each car. I promise I will get pictures of them. One of the 1981s need help..it is surprisingly the original Grey metallic paint. She needs love everywhere. The concern I have is that the upper frame area the connects the battery box through the firewall to the passenger strut tower is rusted all the way through..very badly I might add.
I have yet to decide if I am willing to sacrifice one of the other cars to repair this one or weld in some sheet metal. Is the area actually a support area or just aesthetics? The rusted out area runs the entire length of the battery box to the firewall. I will add pictures soon. Has anyone had to do this repair? If so, did you use a donor car or sheet metal?
https://photos.google.com/share/AF1QipMJ3HPccJUm0vXj4IB49BszvMrGZjnW8kWAvVk8EcAX157B5EQyrfT3aWUl0-ayzg/photo/AF1QipNibPeyCNG_H4D_FbTdUU_kICn_rst_3A3linuR?key=YVJBRXFleFA0NkhpbzZ0S3FRSU95MWUtNzIwZ0NR
https://photos.google.com/share/AF1QipMJ3HPccJUm0vXj4IB49BszvMrGZjnW8kWAvVk8EcAX157B5EQyrfT3aWUl0-ayzg/photo/AF1QipMST_qprhutleZoH38PFPKAzr9IQ2WEI_qYb7_d?key=YVJBRXFleFA0NkhpbzZ0S3FRSU95MWUtNzIwZ0NR
82 931 Ruby red
81 931 Metallic Grey
81 931 Alpine White (red now)
80 931 Guards Red
80 931 Gree/White
93 Ford Mustang GT Impact Blue and Silver
94 Mustang Cobra Black
14 Ram 2500 Black Gold
22 X3M Comp Toronto Red
PostPosted: Tue Nov 21, 2023 6:20 pm    Post subject: Reply with quote
I've seen worse, much worse.
Very much a structural area.
Unless one of your other cars is a total wreck, it would be a shame to cut up a 924.
In any event, you are dealing with a double panel in the outer area so once you have cut out what you need to, use a 'weld-through' primer on all areas. PPG amongst many, makes some great products. As the original metal has a galvanitic coating, you will need to grind a greater area around the area to be welded, to ensure your welds take properly.
After welding, and paint, spray Valvoline Tectyl 506 or similar into those hidden cavities.
safe
PostPosted: Tue Nov 21, 2023 6:51 pm    Post subject: Reply with quote
Structural area for sure. Its a complicated area to fix, because there is more than actual hole you are seeing. Layers...
You don't need to cut up another car to fix it. If you are competent to fix it, fabricating some patch panels from sheet metal is not a problem. Its mostly for aesthetics where it might be easier to make it look factory.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
924gtracer
PostPosted: Wed Nov 22, 2023 9:05 am    Post subject: Reply with quote
Thank you both for your input. I truly do not want to cut up a car. I am an ok welder. Been a few years, i will get some sheet metal stock to get my confidence back and get the Propper welder settings. I have stitched body panels before. I have a MIG with Argon bottle so I feel I could da a good job. I will spray some rust preventative until I have more time to get in there. I will not how much need to the be repaired until I pull the fender.
