tech articles
Guest
PostPosted: Tue Jul 10, 2001 6:14 pm    Post subject: Reply with quote
Email: wdeblaker@hot.rr.com
Date: 10 Jul 2001
Time: 18:14:14
check out nov.94 box vs card
http://popularmechanics.com/popmech/auto2/2HAUQAP.html
Guest
PostPosted: Wed Jul 11, 2001 9:07 am    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 11 Jul 2001
Time: 09:07:29
I second that emotion - you wouldn't believe what you can do with the newer GM Tech II. We have them here at work, and I've used them on my current project... you can read outputs from all or most of the sensors on the car... I can watch the ABS valves cycling... all kindsa rediculous stuff like that... check the output of the ESP sensors, like yaw rate, lateral accel., etc. - and that's just the stuff I know about!
Vaughan
