Chasing down a misfire
bureau13
PostPosted: Tue Jul 05, 2022 2:50 pm    Post subject: Chasing down a misfire Reply with quote
If you recall, I determined that the massive misfire/drivability issue I was having was due to a bad alternator, so as soon as the battery charge dropped it stopped being able to correctly run the ignition system. That problem has not returned...not exactly.
I have noticed that when I "give it the beans," sometimes I get full boost (it's set at about 10psi right now) and it accelerates smoothly up through the revs and sometimes it starts to do that and then instead misfires steadily until I let up on the throttle. When it starts doing this, it tends to keep doing it, although light throttle, gentle acceleration is perfectly fine most of the time. Given what I saw before with the alternator, I'm wondering if I still have some sort of electrical issue causing this. At one point I thought it seemed more prevalent with the headlights on, but I think that is not the case, or at least not a major difference.
Has anyone ever experienced something like this, where maybe some increased resistance somewhere causes misfires?
It's possible the Mittelmotor ignition is more sensitive to things like that...
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
