gegge
Posted: Fri Oct 05, 2012 10:17 pm Post subject: ARP flywheel bolts |
I didnīt want to reuse the 30 year old stock flywheel bolts and expected to pay a lot when buying new ones from Porsche. It wasnīt easy finding short M12 x 1.5 with a shallow head in the hardwarestore either. Especially if you want grade 10.9 or better. Remember that flywheel bolts are different from ordinary bolts and the stress is severe.
Finally I noticed that BMW (E30) M3 with the S14 EVO engine with single mass flywheel used bolts that are very similiar to ours: HEX BOLT M12X1,5X22 11220616143 $2.01
Even better, ARP does provide a kit of 8 pcs in their Pro Series, originally developed for NASCAR competition and has a 200,000 psi rating. #201-2801 for some $50 _________________ Carl Fredrik Torkildsen
Posted: Sat Oct 06, 2012 9:33 pm Post subject: |
Great find Gegge! _________________ 80/81 932/8 ROW |
Posted: Tue Feb 12, 2013 1:10 am Post subject: |
I just installed a set of these on the Club Sport motor and I can confirm that they work perfectly. I also measured the early S2 flywheel (which is what I installed on the club sport), the S1 flywheel, and the NA flywheel with washer, as well as the depth of the blind holes in the end of the crank.
These ARP bolts are 22mm long and have a 8mm unthreaded shank. The heads of these bolts are about 1mm shallower than the stock bolts, so not concern about interfering with the clutch disc either.
All of the flywheels I measured had 9mm or longer depth where the bolt passes through; the blind holes in the crank are ~18mm; so from my measurements and test fitting, it appears that these bolts should work for ALL of the 924 applications. The only one I can't confirm for certain is the late S2 931 flywheel with the rubber damped clutch disc because I don't have one of those flywheels on hand. However, looking in PET, it indicates that those bolts are 18mm long, which is only 4mm shorter than these bolts, and there should be plenty of depth in the crankshaft blind holes to accept the additional length.
I will be adding these to my site later this week  _________________ erstwhile owner of just about every 924 variant ever made |
gegge
Posted: Wed Oct 16, 2013 5:24 pm Post subject: |
There seems to be another ref for OEM BMW M12x1,5x25 in 12.9 quality: 244238930
A picture of OEM 10.9, BMW 12.9 and ARP Pro:
I _________________ Carl Fredrik Torkildsen
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Mon May 09, 2022 3:48 pm Post subject: |
Sorry for rehashing an old thread -
Installing a set of these in my race motor and upon reading arp's instruction it says to install without any washers and specifies a torque setting. So:
1. I assume the round disc that goes between the flywheel and bolts is NOT counted as a washer and should be retained?
2. As the kit is originally intended for a BMW I assume I should use the Porsche specified torque settings?
Cheers
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Mon May 09, 2022 10:10 pm Post subject: |
I believe the torque is generally based on the bolt properties as they want a stress of mol 70% of the yield strength. The original bolt probably a 12.9 has a yield of about 170K psi. The ARP 8740 is a min of 185ksi so it would be torqued a bit higher. That doesn't always hold with specific applications like rod and head bolts. JMO. _________________ Mike
'67 MG Midget Dp
Posted: Mon May 09, 2022 10:11 pm Post subject: |
'67 MG Midget Dp
Joined: 29 Jul 2001 Posts: 9060 Location: Royal Oak, MI, USA
Posted: Mon May 09, 2022 10:58 pm Post subject: |
Yeah, I'd be inclined to use the ARP spec, for exactly this reason... _________________ Vaughan Scott
Posted: Mon May 09, 2022 11:08 pm Post subject: |
What's the arp spec? I seem to have lost my papers.. _________________ 1980 924 Turbo
Posted: Mon May 09, 2022 11:45 pm Post subject: |
...and let me add, please make sure you use whatever lube ARP specs per stated torque. If they require their lube for a particular value, don't use something else.
For me this matters more for something like rod bolts
I found one link indicating ARP lube or Loctite with identical value but it was seller. ARP talks about this subject too in their tech section. _________________ 1980 931 since 1989
daniel
Posted: Tue May 10, 2022 2:34 pm Post subject: |
Hi All
Re torque settings: ARP recommends 105 ft/lbs however haynes recommend 65 ft/lbs. I am not worried about the bolts, I am worried about the thread in the crank shaft!
Re the flat disc/washer. I emailed ARP and they confirmed that the flat disc is fine to use.
I will reply to ARP re the torque settings and see what they say.
Cheers _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
daniel
Posted: Wed May 11, 2022 8:52 am Post subject: |
This is the reply I got from ARP regarding torque settings:
Hi Daniel,
Unfortunately as you are not using these for their intended purpose/application we would not have installation guidelines. I will say though at such a low torque the bolts could come loose.
Best regards,
Zac Kimball
I am a little worried now due to the large difference between stock torque settings and ARP settings. What did those of you who have used these bolts before use?
Cheers
gegge
Posted: Wed May 11, 2022 7:46 pm Post subject: |
The crank is made of forged steel compared to the cast iron block. _________________ Carl Fredrik Torkildsen
