ChrisCXC
Joined: 18 Oct 2019 Posts: 19 Location: Los Angeles, CA
Posted: Fri Oct 18, 2019 7:41 am Post subject: New Race Car to Us, Need Some Advice :) |
Hi Guys,
We run an E30 and a Lotus Elite on the west coast in Lemons, Lucky Dog and Champcar. You can learn more about our team here: https://www.facebook.com/bteamracing/
We've been doing it for over 10 years now.
A couple of us decided to add another car to the group with some new drivers.
We found a killer deal on a 79 SCCA ITB spec 924. It has a NASA and SCCA log book as well as a 2011 tech sticker for Rennsport. It hasn't run in about 9 years though. It seems to have once been a well loved car that was simply abandoned in favor of other racing projects.
Here is what we know about the car so far:
1979 Porsche 924
Caged (seems to be pretty well done)
Still has the stock CIS fuel injection
Ceramic coated headers and race exhaust
Oil Cooler
Stock Radiator
Looks like the head and cam were replaced and not fully re-assembled
Strut bar
944 Suspension
Early 944 Transaxle
Maybe 944 brakes? (disks front/rear)
Phone Dial Wheels (5 bolt)
Lexan rear window (and stock glass too)
Fiberglass hood (and stock metal one too)
The goal is to build a BULLETPROOF car. If there is anything we have learned from all those years of endurance racing is: Make it reliable and very simple. I'd personally love to make it go quicker whenever possible, but never sacrificing simplicity and reliability. Our motto is "keep it out of the pits".
We have all new safety gear, cool suit system, Fire suppression system, radios, Racecapture Telemetry, etc. just ready to drop in.
We simply know nothing about Porsche 924's.
So with that in mind, what should we do?
Ditch the CIS and go dual carbs? Not for power, but simplicity in parts. Tuning carbs on a dyno doesn't scare me as long as it's simple from that point on.
I'm assuming we will need a really good aluminum radiator..... (any recommendations?)
We plan on adding a 22 gallon fuel cell, so no issues with fuel economy as we are limited to 2 hour stints in most series.
Should we add an accusump?
What are we missing?
If we are finishing the top end build, anything we should do/check?
Any help from the brains here would be much appreciated!
Images: (happy to take more if needed, just ask)
https://ibb.co/12XwmFX
https://ibb.co/pXvm4j6
https://ibb.co/nBRwwY2
https://ibb.co/zGjJcwT
https://ibb.co/NTwgSJW
https://ibb.co/YWHPFN0
https://ibb.co/zNxzbcd |
Posted: Fri Oct 18, 2019 11:51 am Post subject: |
Only been racing this year. If the stock radiator has plastic tanks get rid of it. Brass tanks are good if the radiator checks out. Davis Rad. can make you a stock one. Wizard Rad. has one for a 944 Turbo, both in the $600 range. I got an ebay 944 turbo China clone all aluminum for about $200+ and so far so good. Mounting it takes some fab work and the hoses are different sizes so that takes a bit of figuring also. I took 2, 924 bottom hoses spliced together to make one bottom for the 944t and the top hose is a real cluge job. I don't run a fan at this point and with thermostat it stays at 180.
i have untuned 45 Webers and it looks like I should go down to 34mm venturis for the NA head as the flow stalls at about .400 lift. On the NA head polish the exhaust ports up to 300 grit. On the intake side smooth out the machined edge along the bowl behind the valve guide, gently smooth and flatten(a little) the sharp corner on the bottom of the ports, flow goes up about 10%. Match the intake ports to what ever manifold you are using, do not use the gasket as the holes are too big and not necessarily in the right place. I don't drive hard enough yet and seem to be getting about 6 minutes per gallon. I use rev limit of 6k with stock rod bolts. An MSD 6 ignition does wonders.
Look at what the NASA Spec944 guys do for suspension stuff, basic, but works. Making Delrin bushings work on the front of the lower control arm is pretty ugly and on the TB carrier the Delrin can be gruesome. I use aluminum front TB carrier mounts and a hard Powerflex Black TB carrier bushing. It took about 3 hours to fit and is just a fraction of the Delrin ones. Look up Pub Racing website for Vaughn's build also as a long step up from Spec944. I have GAZ Gold Pro coil overs at 400 lb in front and 275 back to go with a 23.5(stock) torsion bar. I have 944t sways front and rear(24 hollow, 18 rear on a stock suspension that works perfectly and 968 30mm front, and 22mm adjustable Weltmeister rear on the race car. _________________ Mike
'67 MG Midget Dp
Posted: Fri Oct 18, 2019 7:15 pm Post subject: |
The standard radiator works fine for endurance racing in my experience, just have good airflow through the oil cooler, to be on the safe side. And a radiator in reasonable good condition.
Brake caliper rebuild is definitely on the must do list, but you might have planned that already. With the correct pads the braking system is more than enough, but some ducting is always nice to get even better pad life, but you already know that if youve done endurance racing.
Oil system should be good, just keep the level close to the max.
I would do some simple ports polishing as mike says, theres some easy gains there if you already have the top end apart. Change all seals and gaskets of course. And all old water hoses while you have everything of.
Check through all the bushings and ball joints, its an old race car, things might be worn out.
If everything works i would keep the CIS, but it looks like everything is stripped on the pics, so carbs might be the easiest route. _________________ 1980 924 Turbo
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Fri Oct 18, 2019 11:34 pm Post subject: |
If the car is running as-is, I'd leave the CIS. It is more reliable IMO than carbs, once it's running properly. But they don't like to sit, so it may not be any longer.
Stock rad can work fine - that's all we've ever used. That said, you'd save a decent bit of weight running an aluminum one. Maybe have the existing one tested by your local rad shop first.
Accusump would be very much adviseable, yes. Worth putting in a remote filter mount, while you're at it, for ease of maintenance etc.
And, in that area, a good heat shield on the starter plus a remote starter solenoid, so you can restart after spins.
If the head hasn't been installed yet, make sure to check the block for flatness with a straightedge. I went through a whole stack of head gaskets over the last two years because I was too lazy to check it, on a previously-raced high mileage motor, only to realize it was no longer in spec.
I've never found the 5-lug brakes to need ducting, not at ITB levels of power... _________________ Vaughan Scott
ChrisCXC
Posted: Sat Oct 19, 2019 3:19 am Post subject: |
That's great info guys! Keep it coming!
We are planning a work day this weekend to go over all of this and inventory exactly what we have. We should have some detailed pictures afterwards. |
Posted: Sat Oct 19, 2019 3:41 am Post subject: |
The ducting is just to get more running hours out of the pads. Even the drum set-up is good enough for endurance racing, so the 5lug setup is more than enough. We probably have tighter tracks over here than you have, so more braking.
Don't forget to change the water pump, they are cheap, and its old and crusty.
Its incredible how well they work for endurance racing. The team i raced with dragged it out of an old barn, stripped, caged etc. Than put it through a season of 6,12 and 24 hours racing. Bone stock more or less, worked great, as long as it had race pads. Std pads lasted about 45 minutes  _________________ 1980 924 Turbo
Posted: Sat Oct 19, 2019 5:27 am Post subject: |
I swear by the Accu-Sump. I used to race BMW 2002s and the rod bearings would go when the pump cavitated during hard cornering. I put in an Accu-Sump and never had another problem. I put one in my first 924 race car about 5 years ago and didn't have any problems. The new owner forgot to open the valve and spun a rod bearing this year. I have another Accu-Sump in my new 924 race car and no problems in 3 years.
How do you know when an Accu-Sump is working? Feel the body after a run and if it feels warm, that means oil has been flowing in and out of it during your run but the engine keeps constant oil pressure.
I also run the 5 lug setup with vented rotors front and rear but no ducts. I use Performance Friction pads and they last about 10 weekends. No fade. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Sun Oct 20, 2019 12:32 am Post subject: |
| Fifty50Plus wrote: | | I use Performance Friction pads and they last about 10 weekends. No fade. |
That's good to hear; we've seen comparable lifetime out of the KFPs, but they seem to be not as easy to come by.
How's the rotor life on those PFCs? _________________ Vaughan Scott
Posted: Sun Oct 20, 2019 1:06 am Post subject: |
Rotors are fine. My prior 924 still has the original rotors that I installed when the car was built. We've been using the Performance Friction pads in all our endurance cars for the past 15 years. Prior to that we had problems with Cool Carbon continuously changing the compound on us. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
hayeslewis
Joined: 21 Aug 2011 Posts: 74 Location: Alexandria, VA
Posted: Thu Feb 20, 2020 4:46 am Post subject: Prepping a 924 for endurance racing |
I know this is an older post, but I've thought about this for a while and there are all the failures I've had. They're all preventable.
If you're experienced racers maybe you know some of this all ready.
Starter-I've cooked two of them because the bendix/solenoid is right next to the MSDS headers. Put in a heat shield. Vaughan suggests a little sheet metal.
Fix the shift linkage if sloppy. I got all my bits from only944.com-which will work as long as it's not a snail-shell. The sloppy linkage lead me to money shift from 4th to 3rd instead of 5th. Unfortunately the previous owner put in a set of pistons that made it an interference motor, so new exhaust valves were necessary. Even if you have the proper pistons a mechanical over rev like that can crack a lifter. Another good trick is to shift to fifth with your thumb down...or try to avoid 5th, it's a lousy too-tall fuel mileage gear. If you want to spend a few $$$ and you're going to have the tranny out there's a guy called dimi at Flying Horse Motorsport that sells a kit to give you a much better fifth gear. He claims that people like me, afraid to open a transmission, can do it.
Replace the triple square bolts holding the half-shafts with stage 8 fasteners. Those SOBs are famous for falling out. It will cost $100, but it's money well spent. I was leading at Pocono - the one freaking time I could have beat Fifty50Plus, and the damned axle fell out. If you need to save the money then re torque them or maybe a dab of blue lock-tite. But the problem is then need to be torqued to 36ft/lbs-no more. It's super easy to strip them. Don't over do it. If they're seized in you're still going to want to take them out at some point to do wheel bearings. Soak in pb blaster, get a good triple square 8mm bit, and hammer it in to take each one out. If you round out the inner surfaces it's sucks. Yes, once again it isn't the cheapest solution, but better than swearing at a bolt at 3:00 AM
Wheel bearings. I wound up replacing them all when I got my car in less than 24 hours of track time.
Tie rod ends, ball joints, all have gone bad with abuse.
Pick up a spare steering rack-check car-part.
I'd rip out any old wiring completely. IT cars are supposed to have the original wire harness. I had a hot touch ground once and I was with in 30 sec of pulling the fire bottle.
Exhaust. Even balanced and blueprinted the engine vibrates like an outboard. I've had the joint where the header meets the exhaust fail, I've cracked the header before the joint. Eventually I put in a short flex pipe after the joint, it' helps. Make sure the exhaust is well secured.
Fuse box? Carry spare fuses and a way to change them.
Wiring at the fuel pump. CIS needs the fuel pump to work well. Make sure you have full voltage at the pump.
Cooling-the only problem I ever had was stuck in impound on a really hot day. The $50 autozone fan couldn't keep up. Had the stock radiator.
Broke a front sway bar mount once. It's just a tab welded on the lower arm. May want to inspect.
Check the rear toe. If the car has ever been dinged in the rear wheel you can bet the arm is bent and you'll never see it-but you won't be able to get 0 or toe-in at the rear.
Good luck, please post pics and tell stories! _________________ Hayes Lewis
1979 924 HP
1979 924 ITB/HP???
2007 Armada
2013 Hyundai Elantra
1972 MG Midget Vintage project
Unstable electrified three wheeled Bicycle truck |
ChrisCXC
Posted: Sat Oct 09, 2021 6:43 am Post subject: |
Now with a new cage!
Fits our 6'7" driver and our 5'3" driver.
The guys at SpecRacing did a great job. They actually used the car as a template to create a cage kit they will be selling. Just weld it together.
https://www.dropbox.com/s/xve6u5scf8prn1d/IMG_0806.JPG?dl=0
Interior will be cleaned up and re-painted this weekend.
Target race is the LuckyDog race at Thunderhill Nov 20th. |
ChrisCXC
Posted: Sat Oct 09, 2021 6:56 am Post subject: Re: Prepping a 924 for endurance racing |
Thanks for your very thorough list!
| hayeslewis wrote: | | Starter-I've cooked two of them because the bendix/solenoid is right next to the MSDS headers. Put in a heat shield. Vaughan suggests a little sheet metal. |
Got it. I guess we will build a sheet metal shield.
| hayeslewis wrote: | | Fix the shift linkage if sloppy. I got all my bits from only944.com-which will work as long as it's not a snail-shell. The sloppy linkage lead me to money shift from 4th to 3rd instead of 5th. Unfortunately the previous owner put in a set of pistons that made it an interference motor, so new exhaust valves were necessary. Even if you have the proper pistons a mechanical over rev like that can crack a lifter. Another good trick is to shift to fifth with your thumb down...or try to avoid 5th, it's a lousy too-tall fuel mileage gear. If you want to spend a few $$$ and you're going to have the tranny out there's a guy called dimi at Flying Horse Motorsport that sells a kit to give you a much better fifth gear. He claims that people like me, afraid to open a transmission, can do it. |
Yeah, it's sloppy. Do you have a link for the parts we need? I only see a Shift Linkage Arm Kit. Is this all we need?
| hayeslewis wrote: | | Replace the triple square bolts holding the half-shafts with stage 8 fasteners. Those SOBs are famous for falling out. It will cost $100, but it's money well spent. I was leading at Pocono - the one freaking time I could have beat Fifty50Plus, and the damned axle fell out. If you need to save the money then re torque them or maybe a dab of blue lock-tite. But the problem is then need to be torqued to 36ft/lbs-no more. It's super easy to strip them. Don't over do it. If they're seized in you're still going to want to take them out at some point to do wheel bearings. Soak in pb blaster, get a good triple square 8mm bit, and hammer it in to take each one out. If you round out the inner surfaces it's sucks. Yes, once again it isn't the cheapest solution, but better than swearing at a bolt at 3:00 AM |
Hmm... How about grade 8 safety wire bolts? I'm big on safety wiring things from endurance racing experience.
| hayeslewis wrote: | Wheel bearings. I wound up replacing them all when I got my car in less than 24 hours of track time.
Tie rod ends, ball joints, all have gone bad with abuse. |
Yeah, I suspect we will need to do all that to start.
| hayeslewis wrote: | | Pick up a spare steering rack-check car-part. |
Will do.
| hayeslewis wrote: | | I'd rip out any old wiring completely. IT cars are supposed to have the original wire harness. I had a hot touch ground once and I was with in 30 sec of pulling the fire bottle. |
Already done. Putting in a Painless Wiring Track Rocker system.
| hayeslewis wrote: | | Exhaust. Even balanced and blueprinted the engine vibrates like an outboard. I've had the joint where the header meets the exhaust fail, I've cracked the header before the joint. Eventually I put in a short flex pipe after the joint, it' helps. Make sure the exhaust is well secured. |
Got it. Adding that soon.
| hayeslewis wrote: | | Fuse box? Carry spare fuses and a way to change them. |
Always.
| hayeslewis wrote: | | Wiring at the fuel pump. CIS needs the fuel pump to work well. Make sure you have full voltage at the pump. |
We just put carbs on the motor for simplicity.
| hayeslewis wrote: | | Cooling-the only problem I ever had was stuck in impound on a really hot day. The $50 autozone fan couldn't keep up. Had the stock radiator. |
Interesting. This scares me. We run in really hot races sometimes (110f ambient) and very long races. Any advice on how to make the cooling system totally bulletproof?
| hayeslewis wrote: | | Broke a front sway bar mount once. It's just a tab welded on the lower arm. May want to inspect. |
OK
| hayeslewis wrote: | | Check the rear toe. If the car has ever been dinged in the rear wheel you can bet the arm is bent and you'll never see it-but you won't be able to get 0 or toe-in at the rear. |
Good call, will do.
Thanks again!! |
Posted: Sat Oct 09, 2021 7:50 am Post subject: |
I safety-wired my CV bolts for a few years. It got to be such a pain, then Stage 8 came out with their bolts - so much less work. Safety wire is cheaper, but a lot more work every time you touch a CV.
The other half of the cooling system is the oil cooling. Running in hot weather that will be more important for durability than water. Fans don't matter unless you're cruising the strip or on parade duty. Just unshroud that puppy and let it flow. _________________ Vaughan Scott
ChrisCXC
Posted: Sat Oct 09, 2021 8:04 am Post subject: |
| 924RACR wrote: | | I safety-wired my CV bolts for a few years. It got to be such a pain, then Stage 8 came out with their bolts - so much less work. Safety wire is cheaper, but a lot more work every time you touch a CV. |
Copy that. Do you have a link to the kit I need?
| 924RACR wrote: | | The other half of the cooling system is the oil cooling. Running in hot weather that will be more important for durability than water. Fans don't matter unless you're cruising the strip or on parade duty. Just unshroud that puppy and let it flow. |
The car did come with an oil cooler. Seems a bit basic to me. Any you recommend?
Again, as an endurance car, it needs to be bullet proof. I'm happy to over do it to stay out of the pits. |
Posted: Sat Oct 09, 2021 4:29 pm Post subject: |
During over 15 years of track and road driving ive had cvs apart at severally occasions, but never had a bolt come loose, i just torque them according to the book and try to use new 12.9 hardware from time to time.
They can do endurance racing in bog standard form aswell,ive tried that aswell. But as pointed out above aa decent oil cooler is always good for safety, especially in hot weather. _________________ 1980 924 Turbo
