jeneese
Joined: 16 Oct 2015 Posts: 33 Location: Cottage Grove, WI
Posted: Wed Jan 22, 2020 5:38 am Post subject: PAECO Camshafts |
Does anybody know who ground the camshafts and supplied valve spring components from PAECO. They are apparently out of business. _________________ Jim
Porsche 1982 Euro Spec 924
Posted: Mon Jan 27, 2020 10:10 am Post subject: |
Don't know for sure, but when I was looking at cams they looked like they might have been from Webcam. Elgin cams also has quite a few and developed many of the race cams back in the day. Reground cams require additional shims due to the reduced circle dia. Alfa Romeo 9mm shims come in 100+ sizes and are about $4 each. My Elqin 66-15 is great. _________________ Mike
'67 MG Midget Dp
jeneese
Posted: Tue Feb 04, 2020 6:17 am Post subject: |
| MikeJinCO wrote: | | Don't know for sure, but when I was looking at cams they looked like they might have been from Webcam. Elgin cams also has quite a few and developed many of the race cams back in the day. Reground cams require additional shims due to the reduced circle dia. Alfa Romeo 9mm shims come in 100+ sizes and are about $4 each. My Elqin 66-15 is great. |
Cant you give me a part number so I know where to look for these Alfa valve shims.
Thanks
Jim _________________ Jim
Porsche 1982 Euro Spec 924 |
Posted: Wed Feb 05, 2020 2:05 am Post subject: |
Go to Centerline Alfa, looking for 9mm valve stem shims. They are on the early(1960's) twin cam motors.
Using the adjustable lifters you can probably get all the same thickness. Summit Racing and Jegs etc. have fixed thickness cam shims, but finding the 9mm size could be tougher as most valve stems smaller these days. Check with Ferrera valves also. Measure the base(term?) diameter of the new cam versus a stock one should get you close on the thickness needed.
I'm using the Parner cam followers we group bought several years ago and they are solid rather than adjustable and much thinner than stock. We found some known shim stock to stick under the cam followers to make measuring easier, then calc'ed what we needed.
One(of the many) of the design problems of our motor is that the valve train is very heavy so they require stronger springs and load/wear the cam more. Moving all that takes power away. _________________ Mike
'67 MG Midget Dp
jeneese
Posted: Wed Feb 05, 2020 2:17 am Post subject: |
| MikeJinCO wrote: | Go to Centerline Alfa, looking for 9mm valve stem shims. They are on the early(1960's) twin cam motors.
One(of the many) of the design problems of our motor is that the valve train is very heavy so they require stronger springs and load/wear the cam more. Moving all that takes power away. |
Thanks, Very useful information. Raced a Porsche 356 and formula V for many years. Much easier to work on for sure. _________________ Jim
jeneese
Posted: Fri Feb 12, 2021 2:06 am Post subject: |
[quote="jeneese"][quote="MikeJinCO"]Go to Centerline Alfa, looking for 9mm valve stem shims. They are on the early(1960's) twin cam motors.
Where did you purchase the 924 solid lifters. A link would be useful. _________________ Jim
Posted: Fri Feb 12, 2021 5:35 am Post subject: |
https://www.acm.se/en/category/valve-tappet _________________ 1980 931 since 1989
jeneese
Posted: Sat Feb 13, 2021 12:07 am Post subject: |
| Mike9311 wrote: | | https://www.acm.se/en/category/valve-tappet |
Thanks Mike. _________________ Jim
jeneese
Posted: Tue Mar 02, 2021 2:06 am Post subject: Re: PAECO Camshafts |
| jeneese wrote: | | Does anybody know who ground the camshafts and supplied valve spring components from PAECO. They are apparently out of business. |
I have located the cam grinder that PAECO used. Seems to be a reliable small shop with good reviews though I have been unable to reach them.
Demos Cams
Steve Demos
279 Meadow Lane
Jefferson, GA 30549
Office: 706.367.2417
Cell: 706.340.6914
Fax Line: 7063670353
Email: sdemos@windstream.net _________________ Jim
MikeDanger
Posted: Tue Mar 23, 2021 9:49 am Post subject: |
keep us updated, everyone says Welded cams are crap. _________________ It was either this or a giant box of legos |
Posted: Tue Mar 23, 2021 11:55 pm Post subject: |
I talked to Elgin Cam last spring about doing a cam for me. He said that a welded cam would cost well over 1K and take several months due to the welding -regrind- heat treatment/reharden- straighten. This was during initial covid panic and really didn't want to do one as their workforce was way down at the time. I'm using one of his 66-15 regrinds that was hardened(looks like nitrided) with my odd ball shim /follower setup and it and cam followers are showing no signs of wear.
New cams are available from Piper and Newman in UK, I got one from Cat Cam in Netherlands. All cost in range of $400 and delivery in 5-6 weeks. I was amazed when it got shipped on a Friday and arrived the next Wednesday for a shipping cost of about $40.
Elgin said that they need to be hardened due to our extremely heavy valve train weight. My Cat Cam does not appear to be hardened, but my valve train weight will go down by almost 50% so we will see. _________________ Mike
'67 MG Midget Dp
Posted: Wed Mar 24, 2021 12:43 am Post subject: |
I dont think the cat cam is unhardened, it would go wear down very fast.
There are several more cam suppliers, like mittelmotor, ENEM here in sweden etc Newman seems to be the cheapest of them all. _________________ 1980 924 Turbo
Posted: Wed Mar 24, 2021 1:21 am Post subject: |
| C�dric wrote: | I dont think the cat cam is unhardened, it would go wear down very fast.
There are several more cam suppliers, like mittelmotor, ENEM here in sweden etc Newman seems to be the cheapest of them all. |
Just looked at cams a few weeks back. The price of Kent and Piper have gone up 50% in recent times. Newman may have gone up but they are still the best priced here in the UK. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
jeneese
Posted: Wed Mar 24, 2021 7:15 am Post subject: Re: PAECO Camshafts |
| jeneese wrote: | | jeneese wrote: | | Does anybody know who ground the camshafts and supplied valve spring components from PAECO. They are apparently out of business. |
Demos Cams
Steve Demos
279 Meadow Lane
Jefferson, GA 30549
Cell: 706.340.6914
Email: sdemos@windstream.net |
I have since talked to Steve Demos. Interesting pleasant conversation. Needed to know the correct lash clearance for the cam he ground. He is hard to reach.
BTW purchased a new set of cam follows from Newman Cams in the UK. First class quality and service at a very low price compared to OEM. _________________ Jim
