Overhaul Porsche 931 S1 engine
Goto page Previous  1, 2, 3, 4  Next
MOTANUL
PostPosted: Wed Dec 23, 2020 5:21 am    Post subject: Reply with quote
Carrera RSR wrote:
Use Total Seal piston rings.
I have already written to Total Seal. But I did not receive any answer. I later wrote to another member of the sales team - he didn't answer either.
It is possible that the size of the piston on my car is atypical (86.75) and they don't have piston rings for this size.
I managed to buy connecting rod from Romania.
Ref. the Piston rings 86.75:
It is still not 100% clear to me if the pistons rings of the Porsche 924 S2 are identical in size to those of the Porsche 924 S1. I found to buy Genuine piston rings for porsche 924 turbo S2 (86.75 mm).
For main bearings I have: https://www.mespiecesauto.com/en/produit/coussinet-porsche-924-046105501-0406105561-046105591-046198451/
I receive an answer from mittelmotor.de. They have everything (piston rings, connecting rod, main bearings) for 700 euro.
sold Porsche 924 NA 1979
bureau13
PostPosted: Wed Dec 23, 2020 2:50 pm    Post subject: Reply with quote
Maybe a ROW vs US thing? I THINK I read that the US cars had slightly lower compression than the ROW cars, although I don't remember if that were only particular years, or what the numbers were.
MikeDanger wrote:
are you sure s2 is 8.5:1?? thought it was 8.0
944 turbo is 8.5
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Wed Dec 23, 2020 4:19 pm    Post subject: Reply with quote
Have you pulled the pistons to check size? Usually 86.5 then 86.95
Have checked the bores for wear?
S1 and S2 rings are the same
MOTANUL
PostPosted: Wed Dec 23, 2020 8:36 pm    Post subject: Reply with quote
86.75 is my size - repair stage nr.1. An atypical dimension on the verge of extinction.
Bores wear 0.01 mm
S1 and S2 rings are the same: Very happy
After a thorough cleaning, the cylinder head looks like new. The engine block, on the other hand, looks worse - it's very rusty.
MOTANUL
PostPosted: Mon Jan 25, 2021 6:52 pm    Post subject: Reply with quote
I managed to find a Thermostat that opens at 80 degrees instead of 87 (OEM).
I managed to find a thermoSwitch that works between 87 and 82 degrees instead of 92/87 (OEM).
My car is 924 turbo with AC / 1980 and has 2 fans. Can you confirm that the small fan only works when I turn on the AC?
I thought it would help a lot to cool the engine when I'm with the car on the track day for example. Do you think this is a good idea?
MOTANUL
PostPosted: Fri Mar 05, 2021 5:17 am    Post subject: Reply with quote
I started reassembling the engine. The turbocharger has been rebuilt.
k-jetronic and injectors - work in progress.
PostPosted: Fri Mar 05, 2021 8:26 am    Post subject: Reply with quote
I lowered my engine temps and I like it a lot..
I forget what fans do what as oem, but that combination should work..
PostPosted: Fri Mar 05, 2021 11:44 am    Post subject: Reply with quote
Not 100%, since its been a long time since I drove my 80, but I think you are right about the fans. Both only run with AC
PostPosted: Fri Mar 05, 2021 7:45 pm    Post subject: Reply with quote
Looks lovely.........
However I must draw your attention to that gasket on the turbo flange.......with the square hole cut in the centre oil passage.
That gasket with the square inner hole must be something that comes in a kit that turbo rebuilders use. It was on my rebuilt turbo as well, and I gave it no thought, using it along with the o-ring..........bad/bad/bad! The o-ring distorted, the gasket leaked profusively.
A subsequent check of the PET revealed that both turbo oil flange fittings use NO gaskets, simply relying on o-rings.
I'm not saying don't use it....just check fittings carefully.
PostPosted: Fri Mar 05, 2021 11:13 pm    Post subject: Reply with quote
I would not use that gasket; my last turbo rebuild came with it too, but it's not right - just the o-ring.
PostPosted: Fri Mar 05, 2021 11:58 pm    Post subject: Reply with quote
Nice save guys! I didn't even see that gasket because I wouldn't think to use it either. I was more looking at the fact that he has a nice 6:10 housing
MOTANUL
PostPosted: Thu Mar 11, 2021 12:39 am    Post subject: Reply with quote
I will first check how the water temperature is after the engine repair (I removed a lot of rust from the engine block and radiator). If the second fan is also needed to maintain the water temperature, I will make the modification to the electrical installation so that I can turn it on if necessary).
MOTANUL
PostPosted: Thu Mar 11, 2021 12:41 am    Post subject: Reply with quote
Before, he only had that o-ring and no oil flowed at this joint. I already ordered that o-ring (I thought it was better to put a new one - not to reuse the old one).
MOTANUL
PostPosted: Thu Mar 11, 2021 12:44 am    Post subject: Reply with quote
OK. Thank you - I will do so.
MOTANUL
PostPosted: Mon Mar 29, 2021 6:17 pm    Post subject: Reply with quote
The engine is back! (I hope for good ).
Page 3 of 4
