vdub6v
Joined: 07 Jul 2016 Posts: 41 Location: West Chester, PA 19382
Posted: Sat Sep 19, 2020 6:59 am Post subject: 1980 924 starting issues CIS Injection |
2.0L Audi motor, regular 924. Not a 931 Turbo. The car hasn't "ran" since I got it. As far as I know it hasn't ran since 1996. New fuel filter, flushed tank, everything was incredibly clean.
With the WUR either valved off or in series with a pressure gauge I get the following: the gauge applied to the center of the fuel distributor, the pressure climbs to 5 bar (~75psig) while it is running and drops to 3 bar ( ~ 45psig) when it stops.
The car fires up strong (fraction of a second) but will only remain running if I give it gas/hold the throttle body open.
I replaced the intake boot because it was ripped near the auxiliary control valve connection. Still no resolve. I also purchased a known good fuel distributor and installed it. Still no resolve.
Starting - no gas
https://photos.app.goo.gl/ppfSaHEZoBdXVt3H7
Starting - giving it gas (ignore the squealing blower fan)
https://photos.app.goo.gl/oP2tF1LY7tZy1mr7A
What should I be looking for next? |
Witty924
Joined: 05 Nov 2019 Posts: 17 Location: UNITED KINGDOM
Posted: Sun Oct 04, 2020 9:07 am Post subject: |
Hey there.
So the pressures look good on running for you WUR. But it’s the start not holding the revs makes me think your WUR could have a blockage. These things need to be ultra clean. It’s worth removing and cleaning the intake and outtake with cleaner. Next you need to look at the airflow meter. Take the air filter out ask someone to start the car while you lift the airflow plate with your hand, if it fires and stays running with your hand lifting it then you need to recheck the WUR as above as there is an issue with fuel pressure.
Do the air flow meter test before you take the WUR off as a starter. Also check and clean the airflow meter plate, they can get clogged and become sticky, they should be spotless. Check out my vids on the above at witty 924 on YouTube. Hope it helps resolve the issue  _________________ Witty924 - Porsche 924 2.0l NA 1984 |
vdub6v
Posted: Wed Oct 07, 2020 10:17 am Post subject: |
thanks brother, I will check it out. Since it runs the same with the WUR blocked off or inline, I think you conclusion is a likely one.
I will check out your videos and let you know what I come back with. |
Jim d
Posted: Tue Apr 27, 2021 10:44 am Post subject: |
I assume the video "starting - no gas" your were measuring control pressure. correct? This is way to high of pressure to start the car as the engine is too lean. If I assume the ambient is 70 degF, then the control pressure should be 20-25 psig.
Again if the video was showing control pressure, then one of two things are wrong; WUR is blocked or the return fuel line to the tank is blocked. |
