Tim Cuddihy
Joined: 15 Dec 2004 Posts: 47 Location: Toowoomba, Australia
Posted: Fri Feb 19, 2016 8:30 am Post subject: Gearbox replacement advice |
Good morning all, I'm going to be swapping out my gearbox, shift linkages, CV joints and hopefully rear suspension bushings over the next few months and was wondering the best way to get the job done.
I've got almost the whole torsion bar carrier and rear suspension assembly in spares and was wondering if its possible to assemble it all, gearbox and torque tube included then install everything from the bellhousing back? And if it is possible is it a smarter way of doing it?
Thanks |
Posted: Fri Feb 19, 2016 9:08 am Post subject: |
You'll want to do the torque tube and transaxle first, separate of the rear torsion bar carrier.
Otherwise there is just too much to try and juggle, especially since they all mount separately. _________________ Stefan
Posted: Sat Feb 20, 2016 11:12 am Post subject: |
Do you have a snailshell or Audi? _________________ erstwhile owner of just about every 924 variant ever made |
Tim Cuddihy
Posted: Sun Feb 21, 2016 1:08 pm Post subject: |
| Its a snailshell. |
Posted: Sun Feb 21, 2016 11:10 pm Post subject: |
So with the snailshell, it's a bit more complicated because the trans mounts to the torsion carrier. Removal procedure would then be:
1. Remove exhaust
2. Remove half shafts
3. Remove trans
4. Drop entire torsion carrier
5. Remove torque tube
Installation would be the reverse. _________________ erstwhile owner of just about every 924 variant ever made |
