problem in track day
chris79
PostPosted: Sat Jun 27, 2015 9:43 pm    Post subject: problem in track day Reply with quote
Yesterday I was to track day in Franciacorta track, my car recently run well and I have no problem.
But in track when I accelerate quickly the engine misfire a lot and performance are very poor, in road I have not this problem.
It can be the setting of advance ? Now this is set with lamp, it may be that corrector of advance increase too much advance when I accelerate quickly?
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
chris79
PostPosted: Sun Jun 28, 2015 8:22 am    Post subject: Reply with quote
I found 2 possible causes, weather hot might have changed warm control pressure and then fuel mixture (there was 3.2 bar before track day, today is 3.7 bar) or jumps due to driving on track moved screw of co setting (there was little smoke from the exhaust).
It's possible?
PostPosted: Sun Jun 28, 2015 9:08 am    Post subject: Reply with quote
If the WUR caught some gunk and clogged a bit I could see control pressure rising..
Brand new WUR right? Maybe you just broke it in and you need to readjust CO to compensate, you seem to still be within spec...
Higher control pressure would push you lean, I hope you didn't run it too hard like that..
PostPosted: Sun Jun 28, 2015 3:57 pm    Post subject: Reply with quote
Misfire sounds like something else, overheated ignition coil?
chris79
PostPosted: Mon Jun 29, 2015 1:21 am    Post subject: Reply with quote
I tried to regulate Advance and co with small changes but there are no noticeables improvements.
Primary fuel pump is noisy, I have to test even if fuel pump in tank work correctly.
Often poor performance is due to secondary fuel pump, even Engine sound is changed.
There is even noisy from distributor, I have to made some works.
chris79
PostPosted: Mon Jun 29, 2015 5:58 am    Post subject: Reply with quote
Even fuel pump relé very warm.
If fuel delivery for 30s is 750mm and control and system pressure are ok test of pumps is completed?
Or it's possible that at maximum speed the secondary fuel pump don't make necessary fuel to primary pump?
chris79
PostPosted: Tue Jun 30, 2015 7:37 am    Post subject: Reply with quote
this is video of misfires and performances was very bad, maximux sped about 150 - 160 km/h:
https://www.youtube.com/watch?v=ldPCSHoxxlU&feature=youtu.be
fuel pump makes a strange noise, I think no enough fuel comes to the injectors.
Before engine was perfect, then shortly before go on track engine changed sound.
