924 S noise underneath
Guest
PostPosted: Thu Jun 28, 2001 10:54 am    Post subject: Reply with quote
Email: toby.shelton@ci.austin.tx.us
Date: 28 Jun 2001
Time: 10:54:37
Need some help; whenever I let off the gas I hear a popping noise underneath the car when coasting. It doesn't do it if I push in the clutch. Does anyone have any ideas what this may be ?
Thanks...
Guest
PostPosted: Thu Jun 28, 2001 11:42 am    Post subject: Reply with quote
Email: anthys@hotmail.com
Date: 28 Jun 2001
Time: 11:42:31
Toby
Sound like possibly air's getting sucked into the manifold/exhaust system somewhere, ie a hole.
I've had the same problem twice with my 931, once a hole in the exhaust (bit of welding cured that) and currently (i have a stud bolt missing in the manifold that is being sorted shortly)
HTH
Anthony
Guest
PostPosted: Thu Jun 28, 2001 4:02 pm    Post subject: Reply with quote
Date: 28 Jun 2001
Time: 16:02:00
Anthony,
Did it sound like the drive shaft maybe going bad ? Or would that make a noise all the time ?
Thanks..
Guest
PostPosted: Fri Jun 29, 2001 4:41 am    Post subject: Reply with quote
Date: 29 Jun 2001
Time: 04:41:18
It depends on the popping sound, if its a kind of rasping rally car noise I would think its manifold/exhaust, this tends to occur on the overun and is stopped when the clutch is depressed as the engine is disengaged. However if it is a different kind of popping it is possible the torque tube is dodgy, having never had this I don't know what that sounds like, and I though CV joints clunked rather than popped, heh i'm not a mechanic, so I am willing to stand corrected.
HTH
Anthony
