gasket sealers (oil pan, primarily)
kpasko
PostPosted: Sun Apr 19, 2015 4:16 am    Post subject: gasket sealers (oil pan, primarily) Reply with quote
Just got the oil pan back from the hot bath nice and shiny, have some curil k2, reinzoplast, and grey permatex around for sealing the new gaskets...thoughts/preferences?
new water pump too, but probably going to go for k2 on that one due to antifreeze resistance...
thanks!
k
daniel
PostPosted: Sun Apr 19, 2015 10:59 am    Post subject: Reply with quote
Use a sealer that goes rubbery when cured, not hard. I use loctite RTV (red in colour)
1989 944 Cabriolet
kcoyle
PostPosted: Sun Apr 19, 2015 7:49 pm    Post subject: Reply with quote
"Clean vigorously, and affix new gasket to the block with Curil-K2. Slap the rubber caps into the block dry, except for the joints with the cork sections. . .grey permatex there. "
Stolen from Rasta in the thread below. It has worked so far for me..
http://www.924board.org/viewtopic.php?t=39271&view=next&sid=e8f37bc319c2bb65d4cd184f8183c52e
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
PostPosted: Mon Apr 20, 2015 1:11 am    Post subject: Re: gasket sealers (oil pan, primarily) Reply with quote
I use aviation Permatex on that one. Put a little in a dish, then thin it out with brake cleaner. Apply mixture to paper gasket, wait for brake cleaner to evaporate back out. Your paper gasket is now permeated with non hardening sealant. Works perfectly.
kpasko
PostPosted: Mon Apr 20, 2015 5:28 am    Post subject: Reply with quote
thanks for the link to that thread...
maybe you can clear something up rasta-
as quoted, you mention-
but then at the bottom you mention
I use the ultra grey for the joints, Curil-K2 (gorilla snot) for the cork. . .not sure if I would use a drying product on that cork gasket.
seems like one or the other of these is switched up... I'm guessing the first one is correct, as permatex would be the more flexible of the two for the cork...?
Nice trick with the break cleaner too; do you apply anything else after letting the solvent dissolve, or just bolt it up like that?
PostPosted: Mon Apr 20, 2015 6:25 am    Post subject: Reply with quote
Gorilla snot on the cork, ultra grey on the ends of the rubber bits.
Water pump gasket goes on when it gets tacky. Doesn't take that long.
PostPosted: Mon Apr 20, 2015 4:49 pm    Post subject: Reply with quote
FWIW, I soak most of the cork style gaskets in oil! Swells 'em up but keeps 'em from sticking to metal, allowing disassembly with no cleanup. I use this on the water pump, intake, and cam cover.
Of course the end gaskets on the cam cover still need to be RTV'd to the caps.
I have used both Elring sealer and, most recently, Hondabond, on the oil pan with good results.
kpasko
PostPosted: Sat Apr 25, 2015 8:45 am    Post subject: Reply with quote
thanks again for all the tips. finally got to opening the gasket set I got (victor reinz--
as you can see, only one beveled cork bit...is that meant to go drain plug side or opposite? length seems to be spot-on for the drain plug side, but
seems to show opposite...although, it also doesn't show the other side at all...
PostPosted: Sat Apr 25, 2015 8:22 pm    Post subject: Reply with quote
Pic looks accurate to me, same side as the dipstick...
