924 N/A Fuel pump relay failure?
musicalannette
PostPosted: Fri Sep 05, 2014 5:15 am    Post subject: 924 N/A Fuel pump relay failure? Reply with quote
Anyone ever had a fuel pump relay fail on a 924, replaced it, then it failed again after a period of time?
please let me know how long your has lasted.
6 months, 1 year? 5 years and still going?
thanks for your time.
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
Spliffy
PostPosted: Fri Sep 05, 2014 6:35 am    Post subject: Reply with quote
Had mine for 17 years and not replaced the relay, suspect its still the original.
1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen
!tom
PostPosted: Fri Sep 05, 2014 2:25 pm    Post subject: Reply with quote
That's been known to happen when the incorrect relay is being used.
There were several different fuel pump relays used over the years as the design of the fuel system changed. Some incorrect combinations will function for a while.
78 924 NA
5-lug
musicalannette
PostPosted: Sun Sep 07, 2014 2:02 am    Post subject: Reply with quote
thanks tom.
do you know if the internal circuit diagrams for the different relays are on here?
snakoil
PostPosted: Mon Sep 08, 2014 9:30 pm    Post subject: Reply with quote
mine failed before i bought the car,
I had some POS replacement imitation that failed few months after i got the car
then I got a brand new one from VW, took me 1 month to realise this one was DOA
Bought a second one at VW and so far lasted for 2 years
1979 924 NA
