Whispers won't shut off and always going the same speed
Twotone77
PostPosted: Tue Jul 22, 2014 12:26 pm    Post subject: Whispers won't shut off and always going the same speed Reply with quote
My wipers won't shut off and always going the same speed?? I can't figure it out :/ help please
In love with my 1977 924
jason c
PostPosted: Tue Jul 22, 2014 1:04 pm    Post subject: Reply with quote
Why don't you start by telling us what you've checked/found/replaced so far....
PostPosted: Tue Jul 22, 2014 1:11 pm    Post subject: Re: Whispers won't shut off and always going the same speed Reply with quote
you may need a psychiatrist for that...
no really it sounds like the switch mechanism in the steering column might have misplaced one of its contacts...
could be the washer contact not decontacting correctly, if its bent or jammed with a foreign conductive object..
or a short between wires, less likely I believe..
maybe a jammed relay..
does it stop when you pull the relay?
key on off?
witch speed? intermittent?
does changing the lever on the stalk have any effect what so ever?
Twotone77
PostPosted: Tue Jul 22, 2014 1:14 pm    Post subject: Re: Whispers won't shut off and always going the same speed Reply with quote
key on off?
It's only when the key is on and it's very slow speed and I haven't pulled the relay I'll do that and check everything else! Thank you
PostPosted: Tue Jul 22, 2014 1:22 pm    Post subject: Reply with quote
you do know that the lever all the way down position isn't all the way off right? I admit I didn't and thought something was crazy..
think one down, five up... like a motorcycle transmission, neutral is between first and second...
gear pattern compared to wipers..
6
5
4
3 fast as shell go (not that impressive)
2 first steady speed
N OFF
1 slow/intermittent (actually pauses between strokes)
yeah its weird..
and hopefully that's your problem, best case scenario
Twotone77
PostPosted: Tue Jul 22, 2014 1:29 pm    Post subject: Reply with quote
6
5
4
N OFF
yeah its weird..
Holy sh*t no I didn't know that it's my first Porsche and anything older then 1993 lol that's really weird thanks
jason c
PostPosted: Tue Jul 22, 2014 1:50 pm    Post subject: Re: Whispers won't shut off and always going the same speed Reply with quote
Lol!
PostPosted: Tue Jul 22, 2014 1:56 pm    Post subject: Reply with quote
6
5
4
N OFF
yeah its weird..
yeah I just went through all of that mess, even had some custom wiper wiring with 2 3 way toggle switches that some PO did and I had to ditch..
that lever all the way down thing had me crazy.. I even rebuilt the mechanism in the stalk switch and I thought I must have messed something up real bad...
turns out... just a silly lever, that's all
PostPosted: Tue Jul 22, 2014 1:57 pm    Post subject: Re: Whispers won't shut off and always going the same speed Reply with quote
jason c wrote:
Lol!
couldn't help it
ksis
PostPosted: Wed Jul 23, 2014 3:49 am    Post subject: Reply with quote
The wipers have always been slow...think there is dry grease in the motor, I was going to tear it apart when I found. Spare.
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin
