| what do you think of this? Be honest |
| wow awesome idea, ill help you or help find sponsors for a prototype!! |
0% |
[ 0 ] |
| good idea, i think it might work and be useful |
20% |
[ 1 ] |
| not sure |
60% |
[ 3 ] |
| yeah, I don't think its any good.. better luck next time.. |
20% |
[ 1 ] |
| stupid idea.. go get a job at McDonalds |
0% |
[ 0 ] |
| QUIT FILLING MY FORUM WITH NONSENSE!! |
0% |
[ 0 ] |
| Total Votes : 5 |
Posted: Tue Jun 10, 2014 2:50 pm Post subject: intercooler concept |
another crazy engine performance idea...
this is not an AC unit!!!!!!!
sorry but I don't have many friends that are very smart to chat with about things like this...
this works on the principle of utilizing the waste heat of the exhaust to power an absorption refrigeration unit to cool intake charge temperatures..
how absorption refrigeration works
https://www.youtube.com/watch?v=azSDHIXBcOE
this system of using exhaust heat has been proven to work to replace the air conditioning in cars but has not been adopted for any use in automobiles (besides every RV refrigerator fired by propane)...
there is far more than enough waste heat in engine exhaust to power a system like this and they don't just cool, they freeze, many degrees below 0 very efficently
this would make use of free energy witch otherwise would be nothing but waste to increase the efficiency of any car by cooling its intake air temperature (turbo, no turbo, diesel, whatever), that means more horsepower, higher boost ability, and even better cruising MPG due to increased thermal efficiency FREE just by picking up the change that the exhaust throws away
the system is completely sealed, fill it once and it works forever, NO MOVING PARTS what so ever.. NO AC COMPRESSOR JUST HEAT
these things are currently used for industrial air conditioning and refrigeration wherever there is waste heat to be had, and they were invented and used before compression refrigeration was, before common electricity even
and taking heat from the exhaust after the turbo would somewhat condense the air in the exhaust pipe reducing pressure there thereby increasing the pressure differential between the header and exhaust improving the performance of the turbo.. probably so slightly it would be immeasurable tho
I have searched a lot and have never scene even any mention of absorption refrigeration used in intercoolers, a lot of nonsense negative energy gain compression refrigeration but nothing like this...
I don't know I just need someone to bounce ideas off of..
I see no reason that this would not work and be worth the install if it proves to work.. solder copper pipe in the right places, fill it up, no maintenance, good to go
maybe one day ill come up with something useful and end the poverty cycle..
who knows maybe formula 1 will like this thing.. there all about efficiency right now, I believe this could even improve there top spec engines just that little bit more.. _________________ 80 Turbo - Slightly Modified |
Posted: Wed Jun 11, 2014 2:47 am Post subject: |
If it's anything like the propane-fired fridge in our truck camper; it takes a day to cool the fridge. We turn it on, with electricity, the night before we leave (track events of course!). _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Jun 11, 2014 3:14 am Post subject: |
While the ammonia cycle cooling system has been around for about a century, it is very picky about movement. RV units go bad when tilted too much and are slow responders as Dave points out. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Wed Jun 11, 2014 4:42 am Post subject: |
I've done extensive research on refrigerant-based intercooling. Bottom line, heat soak of the refrigerant is a huge issue. Building a system with enough capacity to deal with the demands of boost cooling is not worth the weight, parasitic HP loss, complexity, or cost. The system will heat soak way too fast to be of any practical use.
The Lightning trucks had a variant of a refrigerant based system, and they were only good for drag racing. Your Porsche was meant for road racing, meaning long periods on-boost. Air-to-air is by far the most efficient arrangement for the application, especially if you can minimize pressure drop, number of bends, etc. Best part is, you can supplement it with additional charge-cooling techniques like water sprayers and water meth injection, with no incremental parasitic HP loss, and fairly minimal add'l weight/complexity/cost. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 11, 2014 9:20 am Post subject: |
| Grenadiers wrote: | | If it's anything like the propane-fired fridge in our truck camper; it takes a day to cool the fridge. We turn it on, with electricity, the night before we leave (track events of course!). |
yes this is exactly the same concept as RV refrigerators, they either use a very small propane flame or an electric element to heat the boiler to cool the fridge...
using a system harvesting waste heat from the exhaust we would be talking many tens if not hundreds of times more (completely free) thermal energy available to cycle the system than what little is used to cool a camper fridge.. _________________ 80 Turbo - Slightly Modified |
Posted: Wed Jun 11, 2014 9:26 am Post subject: |
| Fifty50Plus wrote: | | While the ammonia cycle cooling system has been around for about a century, it is very picky about movement. RV units go bad when tilted too much and are slow responders as Dave points out. |
I do have concerns about what effect later forces would have on one of these systems operation, frankly the physics of it are somewhat beyond my scope but there may be a way to rout it where it would be of less consequence... I need a scientist, lol
the fact that they are slow responders is concerning but if this system was used daily it may still be operating carried over from the previous use _________________ 80 Turbo - Slightly Modified |
Posted: Wed Jun 11, 2014 10:06 am Post subject: |
| ideola wrote: | I've done extensive research on refrigerant-based intercooling. Bottom line, heat soak of the refrigerant is a huge issue. Building a system with enough capacity to deal with the demands of boost cooling is not worth the weight, parasitic HP loss, complexity, or cost. The system will heat soak way too fast to be of any practical use.
The Lightning trucks had a variant of a refrigerant based system, and they were only good for drag racing. Your Porsche was meant for road racing, meaning long periods on-boost. Air-to-air is by far the most efficient arrangement for the application, especially if you can minimize pressure drop, number of bends, etc. Best part is, you can supplement it with additional charge-cooling techniques like water sprayers and water meth injection, with no incremental parasitic HP loss, and fairly minimal add'l weight/complexity/cost. |
yes I have scene many examples of intercooler refrigerant from compression systems (running ac compressor)... the fast that the engine is loosing power to the compressor and the minimal capacity such a system can produce I do agree would net a negative performance gain..
especially the systems where they are cooling water for a liquid to air intercooler with 5+ gallon reservoirs is exactly what you don't want in a sports car, lot of extra weight...
the laws of thermodynamics and conservation of energy are absolutely against you with such a system guaranteeing a negative net increase due to inefficiency and the fact that you are using valuable power up in the first place
mind you this concept isn't specific to this little Porsche where it would be extremely complex to package...
maybe where something like this could really shine could be in big diesel trucks to improve long haul mpg, a free way to cool charge air no matter how little could only net a positive result..
I do not see how this could induce parasitic hp loss in any way (other than heat soak witch could be avoided).. there are absolutely no pumps, belts electronics, or anything requiring energy involved what so ever other than the absorption of waste heat from the exhaust (with is free, waste) and the weight of the system witch would be around 40 lbs max..
this system freezes a refrigerator with just a tiny propane flame...
if even half of the waste heat could be extracted from the exhaust and could produce a linear amount of cooling output per heat input it could have a massive effect...
efficient combustion engines on average are only capable of extracting about 25% of the energy of gasoline and turning it into kinetic energy to move the car, the other 75% of the gasoline's energy is converted into nothing but waste heat that requires the engine to use some of its kinetic energy to get rid of with the water pump...
3 times as much waste heat energy is available for the taking than what is used to power the car and I consider that a massive amount on available energy...
tiny propane flame is to freeze your steaks as exhaust (3" blowtorch at 750? degrees) is to (??how much cooling capacity??)
the usefulness of this system is based on how much waste heat can be converted into how much cooling capacity vs the size of the system...
there is many many times more heat energy available than needed, the question is can it be used effectively..
energy differential
750 degree exhaust to 100 degree ambient
200 degree charge to 30 degree goal
if us humans could find a way to use all that waste heat it would quadruple the efficiency of all cars instantly.. maybe in another 1,000 years _________________ 80 Turbo - Slightly Modified |
Posted: Thu Jun 12, 2014 12:01 pm Post subject: |
heres some stuff from this on another forum so you guys can keep up if you like..
been crunching the numbers and as far as the efficiency of there ability to effectively turn heat into cold the numbers work
[QUOTE=67King;11432927]
Furthermore, your estimates on how much waste heat goes through the exhaust are way off. Thermal efficiency alone of an engine is higher than 25%. Will typically be above 30%. Of the at most 70% that is left, a good chunk of it, say 30% will be lost in mechanical inefficiencies, leaving about 40% of indicated power left. Of that 40%, only a portion makes its way into the exhaust system, a good deal of heat will be lost through the walls of teh combustion chamber - the piston, cylinder walls, head, and valves. Leaving the chamber, more will be lost through the exhaust ports. Now we are at the flange to the header. Your EGT's are say maybe 1000 degrees C after all of those losses. Now, I've never quantified what portion of heat is lost up to that point, but I would bet that AT LEAST half. That leaves you with 20%. A lot of heat is lost on its way to the turbo. Then some of that energy is used to turn the turbo. After the heat lost through the turbo, you are probably in the 275 degree range, only an estimate. So of the 20% left, you have maybe 550/1275 (degrees Kelvin) available in the exhaust. So that is a little over 40% of the 20%.....meaning your potential heat for recovery is likely closer to 8%. So from your example of a 200bhp engine, that would mean 800hp indicated, and [COLOR="Red"]you have 8% of that available. That is 64 horsepower at most.
[/COLOR]
Now let us look at what it would take to make this work. At 6,000 RPM at 1 bar of boost, you are looking at 60 RPS*1/2*~5L, or 150L/s of air to cool. To cool that down a single degree C would require about 200 Watts. Since this has to be an enclosed system, you need to pull the temperature down probably 125 degrees C [COLOR="Blue"](assuming from 150 to 25). [/COLOR]That is 25,000 Watts. 1hp = 746 Watts. [COLOR="red"]So that means you need 33 horsepower just to get it back down to where the stock intercooler had it.[/COLOR] That is half of your potential, which sounds like plenty of reserve, but the system will be most efficient at its hottest, and you are trying to effectively "supercool" it relative to the baseline, meaning it gets harder and harder to do so.
The next step would be to determine how big the system would need to be to first extract heat from the exhaust, and second to convert that to usable heat to remove from the intake system. I suspect a system capable of making that kind of power would be absolutely ENORMOUS. I think our refrigerator at home draws about 10 amps of current, which makes it 1200 Watts, or under 2 horsepower. Your system will need to be more than 20 times as big. Why more? Because you don't have a mechanical device to create the pressures needed to run a compact refrigerant system.
So, I don't really think it will work, personally. Guess I kind of just did most of the running it out for you. Seriously, though, back when I used to do this kind of stuff for a living, I used to do all kinds of hairbrained stuff like this, but of course you have to run it out. You may come up with 20 ideas that don't make sense for every one that will work. Again, love the creating thinking, don't get too attached to any idea or thought, just run them out. But also consider that virtually everything that does not rely on technology was figured out in the first couple of decades. One of my mentor's favorites references was a book that was published in 1929.
A much, much, much better way to improve a system would be to use a liquid injection system, which relies of phase transformation, which is orders of magnitude more efficient than trying to use just heat capacities to cool down a system.[/QUOTE]
[COLOR="red"]those numbers look quite promising to me actually[/COLOR]
ok lets say that this thing is only has the potential to almost match the performance of an intercooler, maybe 75%...
if you were to run this after an A2A intercooler that is already bringing the intake temps down from [COLOR="blue"] (assuming from 150 to 25). [/COLOR]
A2A= 150-25=125 C drop
75%= 125C drop X .75 = 93.75C drop
125C drop + 93.75C drop = 218C drop
150C start + 218C drop = -68C intake tempature....
-68C INTAKE TEMPS??? NOW THATS COLD...
I don't think we need anything near that cold of intake temps.. so lets cut that in half..
125C drop + (93.75C X .5 = 46.875C) drop = 171.875C drop
150C start + 171.875C drop = -21.875C intake temps
so if this thing can even do (75% X .5 = 37.5%) 37.5% the work our original A2A is doing then combined we get our intake temps below -20C...
so lets take whats theoretically available
[/COLOR]
8% X .375 = 3%
so we only need to capture just over a third of the 8% waste and we get
intake temps in the -20C or -7F range
now that is some cold dense air with excellent detonation resistance...
remember this thing will go far below ambient air temps ..
A2A can only bring temps down close to ambient, this will be able to get you negative below ambient temps...
I think intake temps of 0C or 32F would be a good goal and were already well past that...
time for algebra..
150C start - 125C A2A + X = 0C X = 25C drop
25/125= 20%
now we only need to get this thing to do 20% as much work as our A2A to get temps to freezing point 0C or 32F
now how much energy does it take to bring your volume of air from 25C to 0C?
compared to useable waste heat?
ok I found a ratio of 5.86 kw/ton efficiency..
and 1 RT = 3.5168525 kW
so that means 5860 watts of heat in and 3517 watts of cold out...
so an efficiency factor of about .6
still looking good
exhaust 45,000 watts in and 27,000 cold watts out..
but were gonna lose some.. cut it in half... no a third to be generous...
1/3= 15,000 watts in and 9,000 watts out
9,000 divided by 200 watts per degree C gets us a 45 degree C drop in temp at 150 liters per second of air...
so after our A2A intercooler getting us down to 25C an additional 45C drop gets us -20C intake temps
and that's estimating being able to use only a third of the available heat energy in the exhaust...
so.... numbers crunched... numbers work....
if it fits under the hood its worth putting under the hood...
now to find out if it fits as far as mass and volume of the system its self needed to do this work..
sorry I don't know how to get the html highlighting to work on this sight but you can see whats red and whats blue..... because it says red and blue.. _________________ 80 Turbo - Slightly Modified |
