installing a universal/gm brake system?
dman58
PostPosted: Sun Mar 30, 2014 12:31 pm    Post subject: installing a universal/gm brake system? Reply with quote
hey first post here, excuse me if its in the wrong category.
anyways i need a new master cylinder+booster in my 80 924 N/A.
it does not have the performance package (it has 4 lug wheels).
it is curently plumbed dual diagonal from the factory.
i know the master is bad, the booster might be useable but id rather replace it.
everything is really expensive, and I'm not sure if i can even get the booster for it so…
i ordered in a master at autozone listed under a 1979. from what i read in the haynes manual the bore and stroke are different, so when it comes in I'm probably gonna end up returning it after comparing it to the old one.
so i was thinking of replacing everything, with this for $300:
http://www.jegs.com/i/JEGS-Performance-Products/555/631016/10002/-1?parentProductId=948836
and i was going to re-plumb it so the front and rear were on separate circuits and add a proportioning valve later if need be.
by doing that i would also be able to add this to one of the circuits to use as a inline staging/drift brake:
http://www.cncbrakes.com/hsb.asp?grp=hsb&subgrp=all&series=412&subseries=
so the problems i see arising from this would be:
attaching the brake pedal
the brake light switches were originally on the freaking master, not the pedal
could i just machine a little adaptor piece for the pedal?
could i just mount a little push switch behind the pedal?
Im wondering if anyones ever tried something like this before, and if theres any crucial problems I'm not seeing.
sorry for the post length i look forward to hearing your opinions/advice.
thanks!
PostPosted: Sun Mar 30, 2014 1:31 pm    Post subject: Reply with quote
You have to do the calculations to determine master cylinder bore size.
The later 924 and 944 used a brake pedal mounted switch, I converted my 79 to use one by cutting the master mounted switch wiring and pulling it into the cabin and connecting the appropriate wire to the switch. The mounting point was already there!
I also converted my car to use a later style brake line routing to use 944 brakes and master cylinder. It was a bit of work, but it allowed me to get away from the manually adjusted rear drums and solid front rotors.
I guess the question I have is this: are you sure the booster is bad? Does it hold vacuum?
Have you checked rockauto.com or other online places to verify you can't find the master slightly cheaper?
dman58
PostPosted: Mon Mar 31, 2014 3:25 am    Post subject: Reply with quote
so essentially a smaller bore would mean it would be easier to lock up the wheels, but require the pedal to move further, right?
also i think the vacuum booster is still good, but its really rusty and I'm not sure how much longer it will last.
i can buy a master cylinder+booster from auto zone for $100, for a 1980 GM.
i was thinking that there were many gm/chevys it was used on that had disk/drum setups, so i might be able to make it work.
also theres only 2 output holes, so I'm guessing id just use one for the front, and one for the back? using T connectors to split them to the wheels?
PostPosted: Mon Mar 31, 2014 9:17 am    Post subject: Reply with quote
Given any thought to a five lug conversion? Seems like staying Porsche would be the way to go if you are going to all that trouble.
!tom
PostPosted: Mon Mar 31, 2014 4:22 pm    Post subject: Reply with quote
A master cylinder rebuild kit isn't all that much.
And why replace the booster if there's nothing wrong with it?
78 924 NA
5-lug
dman58
PostPosted: Tue Apr 01, 2014 5:07 am    Post subject: Reply with quote
when i looked online i couldn't find any rebuild kits for under $100. its the ATE cylinder. unless the volkswagen rabbit or some other car used the same rings.
also i don't want to convert to a 5 lug because all my wheels are 4 lug.
and your right about not replacing the booster, I may just fix the master on there if i can get a kit or a decent priced master but i want to see what other options there are.
also i haven't done any measurements yet but i have a feeling the gm stuff is so big it won't fit behind the air/injection hose :/
PostPosted: Tue Apr 01, 2014 6:04 am    Post subject: Reply with quote
Rockauto has a reman'd master cylinder for $102.79
If you look around, you might find a 5 or 10% off coupon and/or enough other parts to pick up to make it worth your while.
dman58
PostPosted: Thu Apr 10, 2014 11:19 pm    Post subject: Reply with quote
wow thanks, i can't believe i missed that! the only things i am worried about are,
in the haynes manual it says that the master and the booster MUST be the same brand or else they will not work, because the tolerances are off.
and my brake booster is all rusty and it was full of brake fluid. although last time i used it it seemed to be working.
should i be worried about the brand? i swear i thought i saw it say that in the manual. but I'm looking through it now and i can't seem to find it in there. its possible i read that online.
on another note, if i did decide to switch to manual brakes, which I still think is a viable option, what bore size should i use? I'm thinking a 7/8 should be good the original is .905
http://www.wilwood.com/MasterCylinders/MasterCylinderList.aspx?group=Aluminum%20Tandem%20M/C%20Kit%20with%20Bracket%20and%20Valve
i know that too big of a bore the brake will be to stiff, but too small and it won't push enough fluid.
after doing some math it seems like the pedal travel distance would only be about a half an inch farther, at the bottom.
is there any way to 'test' a booster while its out of the car? i have a vacuum pump. because that will be the deciding factor as to whether i buy the original master or not. id like to know whether the booster is good before i order the new part.
although worst case maybe i can find this somewhere else:
http://www.partsgeek.com/gbproducts/MC/94-07122742.html?utm_content=MC&utm_term=1980-1982+Porsche+924+Brake+Booster+A1+Cardone+80-82+Porsche+Brake+Booster+1981&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=CNnt8bWjp70CFbBj7AodoDsAfg
i read that parts geek was no good...
PostPosted: Fri Apr 11, 2014 1:14 am    Post subject: Reply with quote
Nope. Don't worry about it.
You might have to adjust the rod on the booster, but it will work and has been done that way several times without issue.
When you pull the master, pull the booster, remove the rust, clean it out internally with some brake cleaner (careful of your eyes/face), mask off the label and paint it with some black satin or gloss paint. Reinstall and get on with life.
If the booster fails, you'll just have brakes that are harder to use and a vacuum leak, but you won't lose all braking and can bypass it until you can get a replacement (don't forget to look at 944's for newer boosters as they physically bolt up the same way)
txjake
PostPosted: Sat Apr 12, 2014 3:34 am    Post subject: Reply with quote
I don't have my booster hooked up and the brakes work ok, just a bit more pressure needed to stop. a twofah is light enough, I don't see the need for a booster. As soon as I can get/find/adapt, I will take the booster out completely. More room underhood and a few pounds gone.
1978 924, aka The Red Rocker
