ThomasJoseph315 Guest
Posted: Tue Mar 25, 2014 8:03 am Post subject: What's the best stuff to remove the sticky under the hood? |
| You know the glue that held the bubble wrap under the hood, the glue is all over, I'm thinking Goo Gone, but anything else? This stuff is really old. |
billygoat
Posted: Tue Mar 25, 2014 8:53 am Post subject: mineral spirts |
| goo gone has astone bad for paint |
billygoat
Posted: Tue Mar 25, 2014 8:55 am Post subject: remove glue |
| mineral spirts |
Brian L.
Joined: 10 Jul 2006 Posts: 127 Location: Buckley Washington, USA
Posted: Tue Mar 25, 2014 9:25 am Post subject: That suff sucks! |
Nothing works very good. I used gas with 2 stroke oil but I did a complete strip and repaint. I think Mr. billygoat is on the right track, solvent such as acetone lacquer thinner, gasoline just turns it into a gooey mess. I would try some WD40 to break the adhesion. Also here is a long shot, after all the foam is scraped off put a piece of sticky tape on it and see I that will pull it off. _________________ 1980 924 N.A. Monaco Blue owned since 1987
"Remember, sitting on your ass won't finish your project" -Puddins fab shop. |
TYPE111
Joined: 09 Feb 2014 Posts: 76 Location: Perth, Western Australia
Posted: Tue Mar 25, 2014 9:30 am Post subject: |
I know on lotus cars where they use ultra sticky double sided tape people usually recommend bug and tar remover stuff from Auto Glym and the like. _________________ Trust, Then Verify |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Tue Mar 25, 2014 6:48 pm Post subject: |
I like brake cleaner... Plus it smells good  _________________ 1979 924 NA |
jason c
Posted: Wed Mar 26, 2014 9:30 am Post subject: |
| snakoil wrote: | I like brake cleaner... Plus it smells good  |
I did not tell him to say this. I was hoping Rasta would.  |
Posted: Wed Mar 26, 2014 11:58 am Post subject: |
Before
Almost after, going to work on it some more tomorrow.
I used a rag at first, but after a lot of useless scrubbing, I gave up and went and found this. I use these to clean gaskets off of blocks, worked pretty good. I just sprayed some Goo Gone for a cleaner where I was working on and a little a head to let it soak and it seems to be working pretty good. I might end up just repainting it eventually, well see.
