Email: Peter@planb.net.au
Date: 19 Jun 2001
Time: 10:09:10before you throw bucket-loads of cash at the ol' N/A 924, I suggest that you get yourself an engine simulator, build a model of the 924 and then modify it on your PC.
I've just got a copy of Dyno2000 from http://www.motionsoftware.com and it's a great tool. Loaded up everything I knew or could find out about my Euro '79 N/A and it worked out that I should have around 123hp at between 5500 and 6000 rpm - not bad when Porsche quote 125hp at 5800.
I asked it to work out the maximum power by just stroking the motor to 2300cc and trying a whole range of cam profiles - this was using the standard head, no porting or big valves. Best result, 245hp. OK, they were right about the head.
Next test, back to the standard engine and head, add a rootes-type supercharger (the sort of thing I can get at the local Jap yard from a Toyota 1G-GZE motor (not the Mr2) for $450), limit boost to 10psi .. here we go (just the blower, no other mods), 175hp at 6500rpm (same as the euro 931) not a bad start. Double the speed of the blower (they "redline" at around 11000 rpm - the blowers that is) - 193hp at 5500rpm, 197f/lb of torque at 4500rpm, now we's cookin'. Add an intercooler (60% efficient) got to have a 'cooler these blowers heat the air even better than a turbo, hello, 211hp at 5500rpm, 220 f/lb at 4500 (Carrera GT territory now). Pump the boost to 15psi.. what, only 225hp at 5500 - 6000? Check the manifold pressure graph, oops we've flatlined at 28.5psi in the manifold, guess it's time for a little head work.
Next test, back to the standard engine and head, stroke to 2300cc add the same supercharger, limit boost to 10psi .. here we go, 170hp at 5800rpm, 185f/lb at 4000 (euro 931 territory). Double the speed of the blower - 194hp at 5500 and 215f/lb at 4000. Add an intercooler (60% efficient), hello, 208hp at 5000rpm 240f/lb at 4000 (Carrera GT territory now). Pump the boost to 15psi.. what, only 213hp? Check the manifold pressure graph, opps, flatlined again.
In fact I did the test with the blower while I was writing this. Took about 5 minutes to do the test and wite about it.
Now, I'm not saying "get a blower" I'm suggesting spending $40 on software to give an indication of what will work and what won't. Cheaper than buying quad throttle bodies only to find that you get the same urge from a good head job and cheaper too.
This software is a ton of fun and it seems very accurate when you take the time to give it accurate info about the engine.
Now if I can just find flow-bench numbers for the 931 head......
As always, share your experiences.
Peter in Sydney AU.
