Posted: Sun May 12, 2013 8:48 am Post subject: How long is the LHD 931 S2 throttle cable? |
Can someone measure the outer cable cover for a LHD 931 S2 throttle cable please.
The RHD version is a touch too long for my modified TB position and I know the LHD is shorter, but by how much? It may still be too short for my use and need to fab up a custom cable. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sun May 12, 2013 9:07 am Post subject: |
I was just looking at your new manifold/TB, did you bore a couple holes in it to mount the stock cable bracket? If so, which one did you use, the shorter Series II, or the longer series I bracket? You might need to use the Series I throttle 'arm' versus the Series II 'cam' in combination of either bracket. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sun May 12, 2013 6:14 pm Post subject: |
| Grenadiers wrote: | | I was just looking at your new manifold/TB, did you bore a couple holes in it to mount the stock cable bracket? If so, which one did you use, the shorter Series II, or the longer series I bracket? You might need to use the Series I throttle 'arm' versus the Series II 'cam' in combination of either bracket. |
Neither. The RHD cars use different brackets as the cable starts in a different place. Just need a shorter cable than I have below and the LHD cable is listed as being shorter, but I need to know how short before I order one
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Mon May 13, 2013 1:53 am Post subject: |
Here is a shot of a lhd s2 cable.
Sorry, no metric tape here. This is from where the casing would end, inside the ferrule.About 10 1/2 inch to the firewall lip. Let me know if you need any other shots or measurements.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
Posted: Mon May 13, 2013 2:10 am Post subject: |
Thanks Shawn. Somehow I thought it would be bigger! Off to get a custom one made then _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
