Euro Bumper Alignment Question
sf1
PostPosted: Mon Mar 25, 2013 8:25 am    Post subject: Euro Bumper Alignment Question Reply with quote
Finally had my new bumpers painted and installed . Very pleased with the look:
But on closer inspection the front looks like it's not proper aligned. Looks like it's drooping a bit:
Think it should look like this:
I loosened the mounting bolts a bit to see if I could wiggle it into a better position but it didn't budge. I suspect I'll have to pull the bumper off and modify the mounts though not exactly sure how
Any tips or suggestions on how to approach?
87 924S
79 924 Sebring...gone but not forgotten
PostPosted: Mon Mar 25, 2013 8:29 am    Post subject: Reply with quote
You need Euro front fenders for the complete look so to speak. Check with Dan/Ideola, he has a set of these from me in his stock.
sf1
PostPosted: Mon Mar 25, 2013 8:45 am    Post subject: Reply with quote
So you're saying the bumper won't mount flush to US fenders?
87 924S
The mounting irons will be bent due to a parking bump probably. Use a washer or two behind the top bolt of the irons to push it forward a touch to realign the bumper. Or buy new irons.
sf1
PostPosted: Mon Mar 25, 2013 9:15 am    Post subject: Reply with quote
Yes, that makes sense. The mounting irons looked in good shape but maybe had a slight tweak not readily visible. I'll try a few washers next weekend and see what kind of result that gives.
87 924S
PostPosted: Mon Mar 25, 2013 9:20 am    Post subject: Reply with quote
No, they won't, here's mine from a few years ago. The pic doesn't show the gap like it is in 'real' life!
Here's the same bumper on the Euro car I bought, and Dan has these fenders in Michigan. A tighter 'fit'.
sf1
PostPosted: Mon Mar 25, 2013 10:03 am    Post subject: Reply with quote
I see what you mean. Very interesting. I've always wanted to get rid of the round reflectors anyway...
87 924S
PostPosted: Mon Mar 25, 2013 11:55 pm    Post subject: Reply with quote
Dave, I didn't bring the fenders, those should still be up at your place in WI...
But I do still have that Euro front bumper...it's interesting to me, everyone always says they want one, and how hard they are to find, but no one is willing to purchase it. Shipping is a killer. I'll be taking it to Hershey, maybe it'll find a new home there.
pcelenta
PostPosted: Tue Mar 26, 2013 12:39 am    Post subject: Reply with quote
dave,
that is the cleanest turbo front valence I have ever seen.
vatoisimo
PostPosted: Tue Mar 26, 2013 10:40 am    Post subject: Reply with quote
how much is the shipping?
PostPosted: Tue Mar 26, 2013 9:38 pm    Post subject: Reply with quote
The bumper is sold and will be delivered to its new owner at the Hershey swap meet.
PostPosted: Tue Mar 26, 2013 11:34 pm    Post subject: Reply with quote
Not sure, I'll have to wait till first week of April when I get back to WI.
Spliffy
PostPosted: Wed Mar 27, 2013 12:42 am    Post subject: Reply with quote
The fit on euro bumpers seems to vary significantly. Suspect this is more to do with the moulding. The ends are quite heavy and unsuported, I suspect they may sag a bit over time. have tried replacement mounts, washer and anything else I can think of on mine with limited results. Its better than some worse than others.
1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen
sf1
PostPosted: Wed Mar 27, 2013 9:17 am    Post subject: Reply with quote
Yes, they do appear to sag on each side. Interesting that your experience using washers didn't necessarily fix the issue. I will try and post the outcome.
87 924S
john h
PostPosted: Wed Mar 27, 2013 9:50 am    Post subject: Reply with quote
I assuem you are using the euro mounts as well if so use a big hammer and a long bolt through the vertical on the mounts to re align them. What you can find is with your shock absorber type mounts the front panel can be bent a little which then shows up in the saggy look.
The euro mounts are real flimisy things and it doesn't take much to deform them and the panel they mount on.
Remember a Porsche is not just for Christmas,
if you take it to pieces slowly it can provide anguish all year long!
