installing cam
Guest
PostPosted: Tue Jun 19, 2001 1:27 am    Post subject: Reply with quote
Email: porsche
Date: 19 Jun 2001
Time: 01:27:22
So I took out a cam from a parts car 924 to get grinded now im just fixen to look at my hanes book but how ??? do i install the cam do i just slowly tighten down the bolts holding the bearing cap on in sequance like 1234 or start in the middle ///???
Guest
PostPosted: Tue Jun 19, 2001 12:36 pm    Post subject: Reply with quote
Email: Mark.Dry@mmt.bellhowell.com
Date: 19 Jun 2001
Time: 12:36:51
If I remember correctly from when I did mine, there is a specific sequence and I thought that the
Haynes manual pictured it. I'm at work right now so I can't check for you. I know that the service
manual definitely has it. I believe it was under the head gasket procedure in both manuals???
Good luck Mark
