924 special made parts. Is anyone interested?
mads_gedebuk
PostPosted: Thu Jan 19, 2012 11:53 pm    Post subject: 924 special made parts. Is anyone interested? Reply with quote
Hi all 924/931 fans
In the search of 924/931 specific performance parts I have found a big dark hole of nothing:) therefore have I taken matters in my own hands and started this project.
So far I am building parts from cast aluminum and composites. My goal is to produce high quality parts, made to aviation standards and make them affordable! Because I am not making a 1000ps. china-ish production, I have the opportunity to make one of items, or many variations of one part to welcome your various specific wants.
So far I am planning to make.
Throttle bodies
Individual throttle bodies
Kevlar/carbon Plenum for 931
Cast Dry sump
Dry sump pump bracket
Generator relocation bracket
Cast Remote oil filter
Various valve covers
Distributor delete kit.
If any of you could be interested or have any ideas please write me.
931 Current status: bits and pieces
PostPosted: Fri Jan 20, 2012 4:39 am    Post subject: Reply with quote
I'd recommend when you make the plenum for the 931 to relocate the throttle body to the front of the engine, pointed to the front for a front-mount intercooler...
Might even be worth sourcing a more common throttle body with built-in TPS to fit to it, to support EFI conversion...
PostPosted: Fri Jan 20, 2012 4:52 am    Post subject: Re: 924 special made parts. Is anyone interested? Reply with quote
Throttle bodies
Cast Dry sump
This is what I would like to see made.
I'd also like to see a EFI fuel rail, the intake you make should have the injectors in the runners..
You could also make some new injector bungs if you have the means.
Turbo exhaust manifold?
mads_gedebuk
PostPosted: Fri Jan 20, 2012 5:21 pm    Post subject: RE Reply with quote
Concerning the Plenum I would make it fit front mounted intercoolers! I can’t see any better way of fitting IC in 924.
The throttle bodies will be made with and without injectors. And maybe reversible so you can choose the distance from the throttle valve. I have no plans of making fuel rails but maybe make the throttle bodies to fit fuel rails from another car make.
All parts will be CAD drawn, stress and flow analyzed.
WEASEL149
PostPosted: Sat Jan 21, 2012 2:45 am    Post subject: Reply with quote
I would definitely be interested in any performance/special parts for the 931.
I hope your venture is successful
1979 UK 932
mads_gedebuk
PostPosted: Sat Jan 21, 2012 3:34 am    Post subject: Reply with quote
Year me too
So far i have made the furnace, Flasks and stuff to produce the aluminum castings:) hope I have the first parts by the end of next month. I'm starting with the distributer delete plate.
jamis1970
PostPosted: Sat Jan 21, 2012 4:01 am    Post subject: parts Reply with quote
Love the idea of a alternator relocation bracket.!
1979 924 N/A Not Fast, but a BLAST to drive.
PostPosted: Sat Jan 21, 2012 5:07 am    Post subject: Reply with quote
If you could come up with cores the right size, CGT top mounted intercoolers might be popular. Lots of replicas out there missing this part.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
mads_gedebuk
PostPosted: Sat Jan 21, 2012 5:09 am    Post subject: Re: parts Reply with quote
Me too - lower CG, light weight, cool looks... and fairly uncomplicated to make in cast aluminum.
