fender removal
Guest
PostPosted: Fri Jun 15, 2001 7:19 pm    Post subject: Reply with quote
Email: itsporsche
Date: 15 Jun 2001
Time: 19:19:42
Removed drivers side what about up ther by the headlight the fender panels stuck right at the point/
Guest
PostPosted: Sat Jun 16, 2001 2:35 pm    Post subject: Reply with quote
Email: dy15@yahoo.com
Date: 16 Jun 2001
Time: 14:35:16
there is a bolt that goes from the badge panel to the corner of the fender.
Guest
PostPosted: Sat Jun 16, 2001 11:06 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 16 Jun 2001
Time: 23:06:23
ya there are 3 in addition/under the ariel that hold the fender, sometiems the dirt hides them
I had to get two extension bars and butt the wrench against the wheel, sometimes turning the wheel either which way helps get the rathet in there good.
