Headlights wont retract
daniel
PostPosted: Thu Jan 06, 2011 3:58 pm    Post subject: Headlights wont retract Reply with quote
I am in the process of rebuilding my car and I have a problem with the headlight system. The lights work, and it will rise up, but not retract. Everything worked before pulling the car apart. Heres what I have observed:
With the headlights on, The white wire only has power (this is the wire with a loop) With the heaglights off, there is no power at the plug at all.
My first thought is, the motor cant lower the lights without power, So I applied power to both the red and white wires, seperatly and together. Nothing.
I am not sure if there is a wiring problem or a contact problem inside the motor. Does anyone know the switching sequence to raise and lower the lights?
PS All fuses intact, relay on motor clicks when lights are turned on and off.
Cheers
Daniel
1989 944 Cabriolet
Ozzie
PostPosted: Sat Jan 08, 2011 9:43 am    Post subject: Reply with quote
The cams in the motor or the relay could be causing problems.
Headlight switches fail too.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Sat Jan 08, 2011 10:18 am    Post subject: Reply with quote
the alloy right angle ears that the lights pivot on are prone to cracking and the lights can cock on there pivot.
PostPosted: Sat Jan 08, 2011 12:05 pm    Post subject: Reply with quote
They crack huh... maybe if ya toss,em around... id check the switch
though maybe its a ground or a spring could be binding on one side.
dpw928
PostPosted: Mon Jan 10, 2011 12:21 am    Post subject: Reply with quote
Used to have the same problem on my 80 NA. The temporary fix was to open the hood and tap the relay on the headlight motor. This would normally caused the headlight to retract. The long term fix was to clean the relay contacts on the headlight motor.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
staticsan
PostPosted: Mon Jan 10, 2011 8:58 am    Post subject: Reply with quote
The mechanism is basically a mechanical finite-state machine (says the programmer in me!) and if I remember right, has some not immediately intuitive rules. I found that they will stay up but the lights go out if you turn the ignition switch off but not the lights. It is this sort of subtlety that makes the wiring more complex, though.
It is not hard to pull apart the switching mechanism on the end of the motor. But it's easier to check the relay and the plug; I had a pin nearly fall out the back of the plug which was why mine were unreliable. But the sensor wheel inside can be too greasy, too, which interferes with the contacts eventually.
Wade.
PostPosted: Mon Jan 10, 2011 10:19 am    Post subject: Reply with quote
Yopu know the knob that you spin for hand cranking... do that to see if there binding, then move on to the cleaning the relay contacts.
