SOme kind of stiffy bar thing... wot?
Rattlinbone
PostPosted: Wed Dec 22, 2010 10:07 am    Post subject: SOme kind of stiffy bar thing... wot? Reply with quote
There's something I saw on the Wheeler Dealers show about the 944 that I'd like to get. It's a bar that goes across the top of the engine from the top of one wheel well to the other. It's supposed to add some stiffness to the body. It also looks cool. What's that thing called and where can I find one?
Fred- 1979 924
Khal
PostPosted: Wed Dec 22, 2010 10:19 am    Post subject: Reply with quote
What's it called? I think it might be one of those things that depends on where you come from, where you live and what angle you're looking at it from... but I've always heard them referred to as "Strut Braces".
'80 924 Turbo
PostPosted: Wed Dec 22, 2010 10:30 am    Post subject: Reply with quote
Yes, strut brace. And not worth the time, money or effort if you haven't first addressed the 30+ year old rubber suspension bushings, preferably replacing with something a bit stiffer than OEM rubber.
Rattlinbone
PostPosted: Wed Dec 22, 2010 10:40 am    Post subject: Reply with quote
http://www.bkauto.com/porsche/r1520.php
I think this is what I'm looking for.
And yes, I'm really only interested in them because they look cool. I won't get this set-up until I have tackled all the other issues I have to deal with in my suspension, new shocks, springs, struts and bushings first, silly bolt-on brace thing later!
Fred- 1979 924
PostPosted: Wed Dec 22, 2010 11:58 am    Post subject: Reply with quote
They may look cool but make getting to other parts of the engine more annoying
1979 NA
my Porsches Arse!!!
PostPosted: Wed Dec 22, 2010 11:02 pm    Post subject: Reply with quote
What Scorp said - I have a tough time even putting oil in without spilling.
They're a PITA.
Of course, ours is functional... but that's cause there's no other rubber in the front suspension.
BTW, note that the strut tower braces don't usually clear the 924 intake and hood without modification... at least, the KLA one I have doesn't. I have spots rubbed out on the intake, the hood, and the bar itself.
gla924sem
PostPosted: Thu Dec 23, 2010 12:27 am    Post subject: Brace Reply with quote
Not sure which brand I have but no problems with adding oil.....clears the manifold fine and no hood issues.
Only issue is I need to remove the bar to power bleed the brakes. Cap to MC won't fit past it.
Mmagus
PostPosted: Wed Jan 05, 2011 5:38 am    Post subject: Reply with quote
If you are after looks I agree they do look nice. If you want performance then, after replacing/removing all the rubber and replacing them with solid mounts, consider a LOWER strut brace, it gives you better bang for your buck, and dosn't interfere with adding oil.
'87 924S "Tuffy"
Dead Pets Racing
PCA Member
PostPosted: Wed Jan 05, 2011 7:40 am    Post subject: Reply with quote
Subframe is a lower strut brace.
1981 924 Turbo sold
1982 924 Turbo sold
