oldmanwintersret
Joined: 06 Apr 2009 Posts: 133 Location: San Antonio, Texas
Posted: Sun Nov 07, 2010 5:54 am Post subject: No fuel - No fire |
I am lost. Been trying to get my 924 NA (1982) running again for over a year, with no success and am trying to save up extra cash for a real Bosch mechanic. The car has no spark and no fuel. the following has been done:
A. Dizzy rebuilt by a Bosche certified shop. Correctly indexed it and the rotor pointed just before cylinder 1.
B. The ignition switch has been replaced with a new one.
C. The ignition module has been replaced with a new one.
D. The wires from the coil to the fuel pump relay have been replaced.
E. The wire from the coil to the ignition module has been replaced.
F. The EIS has been bypassed per the FSM
G. Battery has a full charge
H. Getting 12 volts on both sides of coil to ground.
I. Getting 12 volts to terminal 4 on the ignition module
J last time I checked which was a while ago bypassing the relay gives me fuel per the FSM but no spark.
K. Fuel pump relay bought new and replaced.
Any ideas would help. _________________ 1982 Porsche N/A |
Ozzie
Posted: Sun Nov 07, 2010 7:12 am Post subject: |
terminal 15 of the ignition module should get power when cranking and ign on. Ok - 4 for ox sensor- sorry.
Try 12volt off the battery to the coil direct _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sun Nov 07, 2010 11:19 pm Post subject: |
Bad grounds maybe? I added another ground from the motor to frame and it seemed to make difference. _________________ I got nothin'
Uhhh...you got any pics? |
Posted: Mon Nov 08, 2010 3:47 am Post subject: |
This type of problem can usually be resolved by following the test procedures in the factory service manual. _________________ White 87 924S "Ghost"
Feltron
Joined: 11 Jul 2010 Posts: 44 Location: Port Murray NJ
Posted: Thu Nov 11, 2010 4:41 am Post subject: |
| Does the fuel pump run and the gas just isn't getting to the motor or when the key is on is the fuel pump off? |
oldmanwintersret
Posted: Thu Nov 11, 2010 3:34 pm Post subject: |
The only time I can get the fuel pump to run is bypassing the relay per the FSM and Haynes. Right now am suspecting a timing issue and intend to check that out again. But I dobt that will correct the no fire no fuel syndrome. _________________ 1982 Porsche N/A |
Ozzie
Posted: Thu Nov 11, 2010 9:09 pm Post subject: |
do you have continuity from 1 on the FPR to the 16 (or 6) on the TIU? _________________ Porsche 924 1984 (UK import) NA
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Fri Nov 12, 2010 12:49 pm Post subject: |
| oldmanwintersret wrote: | | The only time I can get the fuel pump to run is bypassing the relay per the FSM and Haynes. Right now am suspecting a timing issue and intend to check that out again. But I dobt that will correct the no fire no fuel syndrome. |
The fuel pump will run whilst it's cranking. The relay uses the tacho pulses to stay in. Maybe that wire is faulty? I can't remember where it comes from, either the coil or the TAI unit.
Wade. |
oldmanwintersret
Posted: Sat Nov 13, 2010 4:47 am Post subject: |
That wire was replaced. It failed the Ohm test specified by the FSM. It goes from the coil to the relay per the Haynes and FSM electrical diagrams. I'll have to do some research on the TAI unit and the TIU. As I do not know what they are as of yet and if I have them. _________________ 1982 Porsche N/A |
staticsan
Posted: Sat Nov 13, 2010 9:51 am Post subject: |
| oldmanwintersret wrote: | | That wire was replaced. It failed the Ohm test specified by the FSM. It goes from the coil to the relay per the Haynes and FSM electrical diagrams. I'll have to do some research on the TAI unit and the TIU. As I do not know what they are as of yet and if I have them. |
Gotcha. Funny how I can see that in the OP now and wasn't sure before...
The "ignition module" (located behind the left headlight) and the "TAI module" are the same thing. TAI = Transistor Assisted Ignition which isn't as complex as it sounds. Its main advantage is that it can provide a clean pulse for the coil from the reluctor or inductor. This means a single spark for the cylinder which means better and more reliable engine power as it revs.
Wade. |
oldmanwintersret
Posted: Sat Nov 13, 2010 1:17 pm Post subject: |
Thanks for the clarification Wade. The unit (ignition module) was replaced with a new one during initial troubleshooting. Wires to it were tested/replaced/repaired per the FSM. Tomorrow if I am not lazy from working the night shift, I am going to take a look at the timing again. For a sec, got a quick squirt of fuel while messing with the dizzy. _________________ 1982 Porsche N/A |
oldmanwintersret
Posted: Sun Nov 14, 2010 5:47 am Post subject: |
Out of curiosity I ran a jumper wire from the battery to the negative side of the coil. Viola had a strong fuel flow, but no spark. How can this info help me out? Re-stabbed the dizzy on cylinder 1 indexed it, and lined up cylinder 1 o the dizzy and verified it is on TDC also. _________________ 1982 Porsche N/A |
PeterW
Posted: Sun Nov 14, 2010 7:05 am Post subject: Re: No fuel - No fire |
[quote="oldmanwintersret"]
Any ideas would help.[/quote]
Well... I'm not a mechanic, but this could indicate a number of things. My understanding is that one of the leads of the coil SHOULD be grounded - if it reads 12 volts on both sides, it's not. This would lead me to think:
A) The coil is internally shorted and should be replaced. Potential damage to other circuits. Easy swap.
B) The ballast resistor is bad/open/disconnected and not closing the circuit. This is supported by the fact that when you grounded the coil, other things started to work.
Since you have checked/changed the transistor module and wiring (you did put the ballast resistor back in I assume) I would check the other ballast resistor (IIRC 1.5 Ohm, not 1.0 Ohm) and see if you have a complete circuit. _________________ 1980 931 |
oldmanwintersret
Posted: Sun Nov 14, 2010 7:27 am Post subject: |
From what I understand from the FSM if I am reading it correctly terminals 1 and 15 on the coil to a ground should read 12 volts with the key on. Resistance between 1 and 15 are 0.62 which is acceptable.Voltage on H+ and H - are 11 volts. The only thing I can see is that the timing might be still off, even though it is indexed correctly. _________________ 1982 Porsche N/A |
PeterW
Posted: Sun Nov 14, 2010 9:39 am Post subject: |
Sure - but I don't think that isolates the fault. Divide and Conquer.
There should be 2 wires on 15. One should measure 1 ohm to pin 4 of Ignition box - you said that you checked this, and I bet you have 6 or 8 times at least, so I buy that.
The other should lead to the starter solenoid assuming that I'm looking at the correct diagram here. It needs a 1.5 Ohm ballast resistor. This looks to be the wire you replaced, which makes sense. If there was a short to the high voltage side internal to the coil, it may have taken this resistance wire component out. You fixed a fault that was caused by? Was the resistance too high before you changed it? It's possible that the coil short caused the resistance wire to fail on you.
It looks to me as though there is only 3 components in the circuit - the coil, the transistor box, and the ballast resistors. When you don't have a drop in voltage, you don't have current flow per ohms law. Yea, I know, there is a low duty cycle pulsing that you can see with a scope, but if you have a shorted coil you won't get any High Voltage even if the primary side measured correctly. (At DC it's shorted anyway, so measuring the resistance doesn't tell you if the short exists, only that it has not gone open. A short between the HV side and the Primary does not change the DC value, only the effective turns ratio, which will prevent the coil from providing a High Voltage.)
The only other test that I can suggest, without changing components, is to get an "In line Spark Plug Tester" - it's a little light that has a fits between the plug boot and the spark plug, and lets you see that you actually have a high voltage. Search Amazon and they have them for under $10. I saw them at Autozone for $4 on sale. You can screw with the dizzy all day, if you don't have HV you don't have spark. It has been worth the $4 for me to have the tool.
Now, I'm not saying that I'm 100 percent certain on this car mechanics stuff, and clearly if you don't have fuel it won't fire either, but the transformer stuff I do know. _________________ 1980 931 |
