924 valve springs won't come out
Guest
PostPosted: Sun Jun 10, 2001 7:20 pm    Post subject: Reply with quote
Email: obin_jess@hotmail.com
Date: 10 Jun 2001
Time: 19:20:50
i am having a bitch of a time trying to get the valve springs out of my 924 cylinder head. i got a valve spring compressor from Sears and it just could not compress hard enough to get the valve springs out.
i saw that the tool to do this 5-minute job is $125!!!! does anyone have one of these tools that i can rent/borrow? any ideas as to how i can get these valve springs out without busting the cylinder head?
thanks!
obin
Guest
PostPosted: Sun Jun 10, 2001 7:30 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 10 Jun 2001
Time: 19:30:26
i used a hydraulic press, was easy as pie, can you find a shop and ask to borrow a press?
you need a pipe the size of the bore (smaller of course) and some tape or plastic around the pipe, and a cut out in the pipe so you can stick pliers in and pull the valve keepers out.
