Steering Rack
PostPosted: Mon May 17, 2010 11:54 am    Post subject: Steering Rack Reply with quote
Shaggy's rack seems to have a bit of lateral play on the passenger side. Diagnosis? Adjustment, rebuild, trash?
PostPosted: Mon May 17, 2010 2:09 pm    Post subject: Reply with quote
If you can get the parts, it should be rebuildable as it is likely a bushing that's worn.
If the bellows and tie-rods are intact then you should be okay to use it until you can find parts/time.
PostPosted: Thu Jul 15, 2010 11:37 pm    Post subject: Reply with quote
Did you come up with a solution to this problem? My rack is rattling on the passenger side like yours..
zimm
PostPosted: Thu Jul 15, 2010 11:50 pm    Post subject: Reply with quote
I've "fixed" them in the past by inserting a wedge to tighten the plastic bush
was a temp fix, but lasted for years..
6 bikes, 9 cars, 1 van.... the more you have the less they work.
bear924
PostPosted: Sun Jul 18, 2010 12:02 pm    Post subject: Reply with quote
Check the play isn't your upper tie rod, check under the steering rack boot on side in question.
