931 Engine Install
Goto page Previous  1, 2, 3, 4, 5, 6
stevekat
PostPosted: Sat Jun 19, 2010 3:14 am    Post subject: Reply with quote
I am pro-reading-the-manual.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
gegge
PostPosted: Sat Jun 19, 2010 3:27 am    Post subject: Reply with quote
I´ve got the program but it doesn´t connect to the unit.
Wasn´t the 931 map a plain flat 3bar across the range? And later they did lean the lower and mid slightly? I would like a fatter top and warm-up as well.
Carl Fredrik Torkildsen
PostPosted: Sat Jun 19, 2010 6:03 am    Post subject: Reply with quote
If the program is not seeing the controller, you may need an updated driver for the USB serial port emulator. They have it on the Unwired Tools website.
And, on the wiring, we are both saying the same thing. I connected the white wire to the pulsed side of the coil, which is the one with the green tach wire coming off of it.
PostPosted: Thu Jun 24, 2010 10:11 am    Post subject: Reply with quote
Thanks Rasta. RE: the brake setup, I have 968 running gear for the club sport project, and am debating about my plumbing, so it's helpful to know that you found the 931 master cylinder and X-split to be acceptable with the brembo calipers.
CAVEAT: 86 951 fronts are 36 & 38 mm. 968 fronts are 36 & 40 mm, M030 968 fronts are 36 & 44 mm. Might make a difference in pedal. Might not. I expect you'll let us know.
MORE IMPRESSIONS: These brakes are f'in sweet. . .well worth the hassle. Smooth, smooth, smooth and STRONG. . .I have been taxing them more and more as Shaggy's rev limits are relaxed!
God, Shaggy sounds good. That cam! What a growl!
WHEEEEEEEEEEEEEEEEEEEEE!
gegge
PostPosted: Thu Jun 24, 2010 4:23 pm    Post subject: Reply with quote
Integral Stage I 268º/260º?
PostPosted: Fri Jun 25, 2010 1:03 am    Post subject: Reply with quote
Yes.
PostPosted: Fri Jun 25, 2010 2:26 am    Post subject: Reply with quote
oh i envy you guys playing with that UTCIS thing...wish i had one as well
PostPosted: Sat Jun 26, 2010 5:43 am    Post subject: Reply with quote
Shaggy celebrates new life at FOTM.
PostPosted: Sat Jun 26, 2010 6:24 am    Post subject: Reply with quote
wow !
drop dead gorgeous !
PostPosted: Sat Jun 26, 2010 7:30 am    Post subject: Reply with quote
Jealous that you got a parking spot right out front. Very nicely done sir!
Page 6 of 6
