fuel distributor
PostPosted: Sat Jun 02, 2001 9:06 pm    Post subject: Reply with quote
Email: kaffine@hotmail.com
Date: 02 Jun 2001
Time: 21:06:33
Does anyone sell a rebuild kit for the fuel distribitor? I took a spare one apart and it doesen't look that hard to rebuld I just can't get the center tube out but I haven't tried very much. Thanks.
PostPosted: Sun Jun 03, 2001 5:44 pm    Post subject: Reply with quote
Email: s2003r@yahoo.com
Date: 03 Jun 2001
Time: 17:44:18
i don't know if it's true or not, but i've always heard that they're not rebuildable and you can't exchange parts between two identical distributors. the reason given is that they are machined to such tight tolerances that the plunger is made to fit the individual distributor its going in. please correct me if i'm wrong so i don't buy a new one when mine finally gets clogged up.
PostPosted: Sun Jun 03, 2001 5:58 pm    Post subject: Reply with quote
Email: themechanic@talk21.com
Date: 03 Jun 2001
Time: 17:58:14
You can buy rebuilt exchange units in the UK but you can't buy the spares. When they're rebuilt you need dedicated equiptment to set them up.
PostPosted: Mon Jun 04, 2001 6:52 am    Post subject: Reply with quote
Email: wdeblaker@hot.rr.com
Date: 04 Jun 2001
Time: 06:52:45
detailed function and diagnostic info about CIS
http://www.autoweb.lycos.com/garage/encyclop/ency07b.htm
PostPosted: Mon Jun 04, 2001 7:49 am    Post subject: Reply with quote
Date: 04 Jun 2001
Time: 07:49:48
fuel injection diagnosis and repair video $69.95
http://www.auto-video.com/video.htm
PostPosted: Tue Jun 05, 2001 1:14 am    Post subject: Reply with quote
Email: martiniwh1@aol.com
Date: 05 Jun 2001
Time: 01:14:20
often the problem is contamination, and the unit doesn't need rebuild, but cleaning. While its usually not advised, You can do it yourself if you are very careful and know what you are doing, especially to avoid leaks after re-assembly..
PostPosted: Fri Jun 08, 2001 12:55 am    Post subject: Reply with quote
Email: jod3511@home.com
Date: 08 Jun 2001
Time: 00:55:03
I got 1 that works for 200.00
Date: 08 Jun 2001
Time: 00:55:42
