931 block
Guest
PostPosted: Thu Jun 07, 2001 5:12 pm    Post subject: Reply with quote
Email: swicks@motorpics.co.za
Date: 07 Jun 2001
Time: 17:12:57
I have found a bargain 931, problem is the block has a hole in it and the head is scrap. Some of the injection system has also been stripped off and lost.
Is the crank the same as the Audi, I read somewhere that the big-end journals are bigger?
I assume the block is identical to the Audi.
If I do buy it I will use it as a non turbo track car.
