Spring on Snail Shell linkage
Guest
PostPosted: Sun Jun 03, 2001 4:39 am    Post subject: Reply with quote
Email: polaris7@softhome.net
Date: 03 Jun 2001
Time: 04:39:16
Hello all, I have my trans and drive tube out (for clutch replacement) on my '79 N/A (hopefully not N/A for long: ), working on supercharger install). I am re-working the linkage (taking out the old ball and socket that is causing problems and replacing with a universal type joint used for recumbant bicycle stearing). When I got the car, the spring at the base of the shifter was not connected to anything, I was wondering if anybody knew how the spring is supposed to be attached, or if I should leave it completely out....Any info would be helpfull.
Thanks,
Alex Roy
'79 White N/A, Ported head, Dual 40 DCOE Webers
Guest
PostPosted: Mon Jun 04, 2001 1:00 pm    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 04 Jun 2001
Time: 13:00:01
My understanding is that this should probably apply pressure on the shifter itself to push it to the left, thereby centering the shifter in the 2-3 gate. Mine also was non-functional. I think this is due to dicking around with the shifter knob too much LOL
Good luck.
Guest
PostPosted: Mon Jun 04, 2001 4:23 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 04 Jun 2001
Time: 16:23:31
speaking of snailsheel shifter springs, Performance Products sells a bushing kit, that they advertise as also containing the "updated shifter spring." Anybody know anything about this spring? I mentioned it at the dealer and they said that they didn't know anything about it.
Guest
PostPosted: Mon Jun 04, 2001 10:32 pm    Post subject: Reply with quote
Date: 04 Jun 2001
Time: 22:32:36
Here are some pictures of my ball-joint bushing fix.
http://home.att.net/~manxandmoxie/linkage.jpg
http://home.att.net/~manxandmoxie/linkage2.jpg
