replacement seats from UK cars
Guest
PostPosted: Fri Mar 17, 2000 3:45 pm    Post subject: Reply with quote
Email: nickmail@btinternet.com
Date: 17 Mar 2000
Time: 16:45:18
I have a 80' 924 with tired out seats (black pin stripe. the previous owners covered the rips with
overcovers, but they are now so out of shape that
any cornering at speed puts my back out, since there is no lateral or lumber support left in them
What I want to do is throw them in the bin, and put in some cheap replacements. I could get a pair of gray recarros from a scrapped ford UK-XR3i
for about £40, but would they, or anything else for that matter- be easy to fit.
Nick
Guest
PostPosted: Fri Mar 17, 2000 8:56 pm    Post subject: Reply with quote
Email: bcdodd@rapfire.net
Date: 17 Mar 2000
Time: 21:56:47
Define easy to fit. What you might want to do is pull your passenger seat and make some measurements of the track length and width from one track to the other. Plus you can see how they attach. The biggest thing is to be able to use those slide tracks. You can come up with ways to bolt those rails to a donor seat then you know you can easily bolt the seat in as long as you keep the same track width. Hope this makes sense. Recaro is a Porsche invested company so there may be some common measurements between seats. You pretty much just have to give it a look and try it out.
