Smoothie Guest
Posted: Tue Aug 27, 2002 6:39 am Post subject: |
| When you're rebuilding, you should check the cylinders for out-of-round and tapering. To do this, you need to measure near the top, middle and bottom of each cylinder both from front to back and sided to side with an inside micrometer. There's a limit to how much of a difference is allowed between the readings - beyond that the cylinder needs to be rebored. |
Rick MacLaren Guest
Posted: Tue Aug 27, 2002 6:46 am Post subject: |
| Yep! |
Smoothie Guest
Posted: Tue Aug 27, 2002 10:22 am Post subject: |
Rick - You just won the award for shortest post ever by Rick! |
Rick MacLaren Guest
Posted: Wed Aug 28, 2002 12:09 am Post subject: |
| Ah! |
