Email: aminolabs@yahoo.com
Date: 13 Mar 2000
Time: 04:07:57It is either gas or electric. Check spark by pulling the cyl # 3 wire out of dist.cap. With engine running, hold 1/4 inch away and see if spark crosses gap. If not, check again with different wire (I.e.: mix 2 with 3). If strong spark, replace (or swap) spark plug and run engine. If still missing check fuel.
The most likely place to have a problem is a blockage in the injector screens or fuel distributor screen (under fuel fitting; lift out with hooked paper-clip). Injector has to be removed and swapped with other cyl. If problem moves with injector, unclog or replace injector.
