1980 924 vacuum
Guest
PostPosted: Tue Feb 29, 2000 9:59 pm    Post subject: Reply with quote
Email: tmurray@stp.tec.mn.us
Date: 29 Feb 2000
Time: 22:59:10
Help!
I am in need of a vacuum diagram for a 1980 924 with the EEC, not EGR
valve. Anyone know of any sources? Just rebuilt the engine, put back in and
not sure where the vacuum lines should run to the thermo-switch. Thanks
in advance to anyone that can help!!!
Guest
PostPosted: Tue Mar 07, 2000 12:42 pm    Post subject: Reply with quote
Email: Apple_Bit@mac.com
Date: 07 Mar 2000
Time: 13:42:03
Your vacummmmm (can't spell- don't want to look it up cauz I am lazy about now system doesn't all need to be hooked up exactly like it was. You can actually modify it a little so it only uses the brakes and the intake and a few other items. (This is the little gadget that runs to your throttle body and to your brake booster)
the haynes manual describes best.
