make it fast??
924turbo_sout_africa
PostPosted: Fri Sep 19, 2008 7:57 pm    Post subject: make it fast?? Reply with quote
Well i've been talking about doing a ic on the car and so on well i'm in the proses of purchasing a bmw 318 so now the porsche will become a weekend toy ,so i was wondering once i do the ic setup can i put in a 1 bar boost spring will this be fine on the motor and so on...cause i have decided to make this thing run like a bad from hell?
Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !!
Last edited by 924turbo_sout_africa on Fri Sep 19, 2008 8:34 pm; edited 1 time in total
PostPosted: Fri Sep 19, 2008 8:15 pm    Post subject: Reply with quote
with a good intercooler you can run 1 bar....if the CIS delivers enough fuel at any RPM in any condition.
PostPosted: Fri Sep 19, 2008 8:33 pm    Post subject: Reply with quote
ok thanks man cause really i want this thing to run down a new golf gti with out any problems hehe
tuurbo
PostPosted: Fri Sep 19, 2008 11:35 pm    Post subject: Reply with quote
Methanol and water injection - good insurance.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Fri Sep 19, 2008 11:51 pm    Post subject: Reply with quote
haha ok well ...i will have to look at all options but i want to push the boost up for sure when that ic is on ...i just wonder how much power it will make
tuurbo
PostPosted: Sat Sep 20, 2008 12:07 am    Post subject: Reply with quote
I personally found 12 PSI a tad scary - wondered if it would hold together. Good enough for me.
With an intercooler AND methanol/water injection, you'd be running very cool. The issue would be fuel - and that's where the methanol doesn't hurt.
PostPosted: Sat Sep 20, 2008 2:48 pm    Post subject: Reply with quote
0.9bar and IC would be pretty safe if everything works as it should. But that is also where the problem is. If i was you i would buy some kind of knock detection system to be able do detect knock wich is the problem when raising boost on our cars..
PostPosted: Mon Sep 22, 2008 5:41 pm    Post subject: Reply with quote
well i was thinking of the same thing as well the fuel ...but i'm running a race motor with 12:1 compression and running a 95 octane with a booster to push it up to 98 and i'm sure this will work in the porsche as well ...well for the knocking mmm that is a problem that i was thinking of i did start to do some homework on that and i whent to autotune they only work on 911 turbo's and they said i should bring it to them and they will run it on the dyno and make sure the timing is right and we might stick in a ajustable wastegate so that i dont run at 1 bar the hole time but at 0.8 in town and 1 bar when wanting to kick ass
