Exploded view of Waste gate
Ants
Guest
PostPosted: Thu May 16, 2002 7:26 pm    Post subject: Reply with quote
Having decided to find a second hand waste gate to try and rebuild, does anyone know of a link to an exploded view of the 931 wastegate (1980)
cheers
ants
Zuffen
PostPosted: Fri May 17, 2002 11:42 am    Post subject: Reply with quote
I'll try and get a going on the wastegate rebuild project. There isn't anything to it and I even think I outlined it at one time here on the board.
While you have yours apart I would like to correspond as I would like you to take some measurements if possible
Bob Dodd - 924turbo@cox.net
Rick MacLaren
Guest
PostPosted: Sat May 18, 2002 12:41 am    Post subject: Reply with quote
Yep. But it's not what you need to rebuild. You're gonna need to know more. Lemme know where you're at and folks can guide you along.
Porsche didn't provide exploded diagrams of the wastegate, perhaps because they sell the unit as a whole unit.
[ This Message was edited by: Rick MacLaren on 2002-05-18 00:46 ]
Ants
Guest
PostPosted: Mon May 20, 2002 1:50 am    Post subject: Reply with quote
thanx for that, i'll let you know if i find a decent one to rebuild
Ants
John H
Guest
PostPosted: Tue May 21, 2002 10:20 am    Post subject: Reply with quote
I've sent the dimensions directly to Bob but if anyone wants the diemsions of the spring it is as follows:
sprung spring length, 6.70 inches (170mm)
coil diameter (Outside dia) 2.74 inches (69.60mm)
coil diameter (Inside dia) 2.34 inches (59.44mm)
link (wire) diameter, 0.25 inches (5.72mm)
pick a point of reference and count the coils for the
entire length. 7.5 turns (top to bottom)
dwak
Guest
PostPosted: Mon Jun 17, 2002 11:50 am    Post subject: Reply with quote
Ants, how did the rebuild go?
dwak
Ants
Guest
PostPosted: Mon Jun 17, 2002 6:26 pm    Post subject: Reply with quote
I only sent off for a second hand one on Friday (14th) so it should be here today.
I'll let you know what state its in.
Ants
Ants
Guest
PostPosted: Tue Jun 18, 2002 12:02 am    Post subject: Reply with quote
ADDENDUM:
Ok so they said it would be 7 days, so hopefully this time next week (24th)
Ants
